'70 Satellite w/383 Engine- Correct Engine Color? #610950
02/11/10 10:08 PM
02/11/10 10:08 PM
Milwaukee, WI
In_The_Pink Offline OP
Milwaukee, WI
What are the factory engine colors for a '70 Plymouth Satellite equipped with the Commando 383 2-bbl or with the Super Commando 383 4-bbl engine?
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: In_The_Pink] #610951
02/11/10 10:49 PM
02/11/10 10:49 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I beleive it would be mopar blue for both.
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: Dougsmopars] #610952
02/11/10 11:52 PM
02/11/10 11:52 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
70 383 2 barrel = Blue
70 383 4 barrel with a/c = blue
70 383 4 barrel non a/c = orange
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: 70gtx440dana] #610953
02/12/10 02:12 AM
02/12/10 02:12 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Does the car have a b'cast sheet?
Holley 4bbl carb = orange
Carter 4bbl carb = blue
& was "SUPER COMMANDO 383" actually used in '70?
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: 6bblgt] #610954
02/12/10 03:43 AM
02/12/10 03:43 AM
Milwaukee, WI
Milwaukee, WI
'fraid not, but it does have an instruction sheet.
I honestly have no idea, I was going by this:
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: In_The_Pink] #610955
02/12/10 04:00 PM
02/12/10 04:00 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
i have a -70 cuda with ac and 4 speed,the engine is orange with a holley 4367.the air cleaner says super commando 383,in orange.N-code.
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: cuda-sweden] #610956
02/12/10 04:25 PM
02/12/10 04:25 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Where does the car in question fall optionwise?
1970 Satellite w/383 4bbl:
auto with A/C - blue
auto without axle package - blue
auto with A/C & "A36" (3.55s) - ??
auto with "A36" (3.55s) - ??
auto with "A31" (3.91s) - orange
3-speed - orange
4-speed - orange
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: 70gtx440dana] #610957
02/12/10 05:53 PM
02/12/10 05:53 PM
Dougsmopars Offline
Dougsmopars  Offline
I thought hemi orange was only used on High Performence motors? Sat with 383 would not be the high performence model. I had a 70 Coronet with 383 all orignal car and motor was blue.
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: 6bblgt] #610958
02/12/10 11:42 PM
02/12/10 11:42 PM
Milwaukee, WI
Milwaukee, WI
3-speed - orange
4-speed - orange
It has a 4-speed manual trans, which means it can only be the 330-horse, 4-bbl 383 since it's in a Satellite?:
I guess that would make it orange?
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: In_The_Pink] #610959
02/13/10 12:34 AM
02/13/10 12:34 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
3-speed - orange
4-speed - orange
Four speed Satellites had the same engine assembly as the RR so it would be the 335 horse orange.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: In_The_Pink] #610960
02/13/10 12:44 AM
02/13/10 12:44 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
It will be ORANGE & the original engine was "HP" (335hp) even though it wasn't spelled out that way in the paperwork shown, RARE insurance beater!
Here's a '70 Sport Satellite b'cast sheet-
383 4bbl 4-spd w/3.23 open rear axle
ENG - 087 - same as similar equipped Road Runner
CARB - 36 - Holley 4bbl #3418 536 - LIST R4367A
We need more details and pics of the car - 2 door hardtop/convertible? Color combo?
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: 6bblgt] #610961
02/13/10 04:41 PM
02/13/10 04:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
My original/untouched '70 Satellite 383 4-bbl A/T car had a turquoise motor & AVS carb. The orange vs. turquoise '70 383 4-bbl deal has been debated here before, and IIRC the orange ones are an anomaly. As previously stated, orange 383s & 440s would signal RR/GTX. '69 RR 383s with A/C were turquoise 330-horse motors, not the 335, had one. Possibly this changed for '70, but not on mine. All the cars I'm referring to were St.Louis built.
The actual blue color came later with the low-compression "smog" motors.
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: topside] #610962
02/13/10 07:59 PM
02/13/10 07:59 PM
Mass
charge70 Offline
charge70  Offline
Mass
My friends early build 70 Charger 500 383-2 bbl,auto w/A.C. this is an untouched original car,has a blue painted engine. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: charge70] #610963
02/13/10 08:27 PM
02/13/10 08:27 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd like to see a picture of that, as well as the SPD. It's #s matching?
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: topside] #610964
02/14/10 03:13 AM
02/14/10 03:13 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Some dirty old cooked paint '70 big blocks look turquoise but were originally blue.
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: 6bblgt] #610965
02/14/10 12:02 PM
02/14/10 12:02 PM
Canada
demon Offline
demon  Offline
Canada
I agree. 1969 was the last year turquoise was used
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: In_The_Pink] #610966
02/14/10 05:09 PM
02/14/10 05:09 PM
California
mickm Offline
mickm  Offline
California
that just strikes me as absolutely hilarious, "no speed control" on the hemi option!
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: 69CoronetRT] #610967
02/15/10 11:26 AM
02/15/10 11:26 AM
California
70SportSatellite Offline
super street
super street
California
When I bought my car in '82 I had to rebuild the engine and I am positive it had never been rebuilt. It is a 4 speed HP stamped block, windage tray, Holley carb and orange. Here is a pic of one of 3 other 4 speed Sport Satellites that I know of and although it appears to have been either touched up or repainted it is an A/C 4 speed in orange. I don't know which carb.
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: In_The_Pink] #610968
02/15/10 01:56 PM
02/15/10 01:56 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
3-speed - orange
4-speed - orange
So, According to this you could get the 330hp engine in a Belvedere? That rocks!
Re: '70 Satellite w/383 Engine- Correct Engine Color? [Re: topside] #610969
02/15/10 04:36 PM
02/15/10 04:36 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I disagree; check out Dan's BS shown above your post. I think 383 4bbl non-A/C, 4 spd cars got the 335hp (E87) motor despite Chrysler advertising to the contrary.
....at least that's my recollection based on all the proof brought forward last time.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
