Rod end clearance......TIGHT
#610643
02/11/10 04:15 PM
02/11/10 04:15 PM
Posts: 1,200 UK
602heavy
UK
Just tore down a 512" low deck , all rod end clearances measured around .016" , # 7 & 8 rods measure @ .006 , this motor was notorius for slow cranking when hot (coil lead off) , two batteries were used to crank this motor. The rods don't look too bad appart from a couple of scuff marks but not gone blue with heat , maybe this was part of the issue maybe not , any thoughts? This is'nt a bearing issue as much as the rods are too tight for the journal.
Re: Rod end clearance......TIGHT
[Re: 602heavy]
#610644
02/11/10 04:27 PM
02/11/10 04:27 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I doubt this is a problem. If it were me, I would polish (wet sand) the sides of both rods, enough to gain a few thousanths clearance and never worry about it again.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: 602heavy]
#610647
02/11/10 05:18 PM
02/11/10 05:18 PM
it's certainly not good the way it is. i'd measure the parts involved to find out where the problem really is and correct it.
[Re: 602heavy]
#610652
02/12/10 12:11 AM
02/12/10 12:11 AM
Posts: 7,506 Az
Crizila
Az
Talked to "Eagle Rods" tech person about rod side clearance: They're recommendation: .015" to .030".
Fastest 300
