I am considering a 360 (OEM crank) build-up and need balancing data. Plan to use KB107 pistons and SCAT I beam rods (0.984 pin, 2.124"). Anyone have the rod total weight (595?), big end weight and small end weight? Also, is it possible to internal balance this combo without mallory? using a non-external balance balancer and flex plate? Plan to use KB lightweight pins, 107g too.
Thanks for any info on this subject, including ring pack weight, lock weight, rod bearing weight, bobweight examples, etc.
John
