Re: Cut to length Pushrods
[Re: redmist]
#609774
02/10/10 10:33 PM
02/10/10 10:33 PM
RapidRobert
iirc you want the right length pushrod, for the pushrod and adj screw to be a straight line (viewed from the front of the eng) w (1) or (2) threads showing (just the bare minimum so the cup doesn't hit the rocker anywhere in the travel range) when your particular cam is @ either 40 or 50 or 60% (I forget which & depends on if SB or BB not on the cam) of max lift w the head mocked up on the deck w the intended thickness of head gasket. You would fab/borrow/buy an adjustable pushrod so you could adj it's length until the imaginary line is straight. this is tied into the wipe pattern from the pedestal height/rocker ratio so definitely check further. EDIT it's 60% for SB (50% BB) and that's 60% (OF WHAT THE VALVE SEES RATHER THAN 60% OF CAM LOBE LIFT) so the rocker ratio (1.5 or 1.6) is being taken into acct)
[Re: RacerGofKGB]
#609777
02/10/10 11:08 PM
02/10/10 11:08 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
It’s been a while but I have mine made to my specs. I bought a adjustable pushrod to find the ideal length then measured and bought the pushrods. Look up smithbros. pushrods. they have a guide for determining the right length pushrod.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: MNobody]
#609778
02/11/10 12:36 AM
02/11/10 12:36 AM
DaytonaTurbo
Manitoba, Canada
Why not just buy ones that are the right length and be done with it?
Because there is no such thing if you have a milled deck, milled heads then combined with a large assortment of head gasket thickness choices.
[Re: RacerGofKGB]
#609780
02/11/10 02:13 AM
02/11/10 02:13 AM
Posts: 1,978 Southaven, MS
BossRide
Southaven, MS
While by no means a high horse power application, my 360 has adjustable pushrods. So far, so good.. and I wind it up pretty tight from time to time. Just a thought...
The Blue Goose
My instagram: Bossride
[Re: RacerGofKGB]
#609782
02/11/10 11:15 AM
02/11/10 11:15 AM
RapidRobert
. And i would feel far superior to all of my friends who have never made their own pushrods.
Absolutely!, priceless! that's why I'm fabbin a set of headers. This is from Hughes', when you get the straight line AND if the wipe pattern is good,(& no interference anywhere) your set. I'd suggest using a hyd lifter w the cup epoxied shut (to duplicate what you are running & I'm assuming hyd lifters) and I have a Q for you would it make sense to epoxy the cups .030" down to match where they will be?? (assuming .030" preload is a good figure). EDIT hughes states that the wipe pattern is more important than an exact straight line and no interference anywhere over the entire travel range is (obviously) #1
[Re: RapidRobert]
#609783
02/11/10 11:36 AM
02/11/10 11:36 AM
Posts: 283 N.E. England
Roppa440
super street
super street
N.E. England
Take your time to get one rod dead right. Then use it to mark and measure all the rest.
Cut 1mm or so too long and file down to size making sure you are square. Clean the edges and put a very slight 45 degree angle on the inside edge to help you get the cup started.
Don't hammer the cup on and bend the rod.
1-2 threads showing under the rocker is ideal. Double check there is no contact between the cup and rocker at any point of its travel.
2002 Chevrolet Corvette 5.7 LS1
2011 Alpha Romeo Giulietta Veloce 1.6 JTD
Because running a Mopar in the UK is getting TOO expensive!!
[Re: Mopar-Al]
#609790
02/13/10 12:22 PM
02/13/10 12:22 PM
Posts: 1,476 Oh
RacerGofKGB
Got The Big One
Got The Big One
Oh
We put them in a lathe, back cut under the cap, and then bevel the pushrod to re install. I did 3 sets this way with no issues. It really is quite simple
So you took pre-made pushrods(or ones with the cap already installed) and cut below the cap and then reinstalled the caps?
I have a lathe, and i was planning on using it to cut down my rods. im sure it will do a lot cleaner job than trying to do it with a bench grinder or something else.
