Factory Vinyl Top - 70 Coronet - Stapled to the car??? #606984
02/07/10 02:08 PM
02/07/10 02:08 PM
Central Illinois
mity225 Offline OP
mity225  Offline OP
Central Illinois
The only staples were in the corners where it might shrink a bit and pull loose from the adhesive. There were 3 to 5 staples in each corner.
Was that common? Should I look for a heavy duty stapler to do that again or is the adhesive better these days?
Any advice available would be appreciated. Thanks!
JK mity225@mchsi.com
Always looking for my next project!
Re: Factory Vinyl Top - 70 Coronet - Stapled to the car??? [Re: mity225] #606985
02/07/10 02:35 PM
02/07/10 02:35 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
With todays adhesive I would not worry about staples..
Re: Factory Vinyl Top - 70 Coronet - Stapled to the car??? [Re: 340dart4spd ] #606986
02/08/10 08:46 AM
02/08/10 08:46 AM
Central Illinois
mity225 Offline OP
mity225  Offline OP
Central Illinois
OK, good advice. I wasn't looking forward to another $60 dollar tool that I'd only use once or twice anyway.
Any suggestions on the best type of adhesive to buy for the top? I've got to get this multi-year project on the road this summer!
Re: Factory Vinyl Top - 70 Coronet - Stapled to the car??? [Re: mity225] #606987
02/08/10 08:55 AM
02/08/10 08:55 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I have had good luck with 3m and Dap brand adhesive..
Re: Factory Vinyl Top - 70 Coronet - Stapled to the car??? [Re: 340dart4spd ] #606988
03/12/12 09:23 PM
03/12/12 09:23 PM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
I'm in the process of replacing the top on my '71 Dart. Today I found two staples at each top corner of the rear window, had never heard of that being done. Weird....
Re: Factory Vinyl Top - 70 Coronet - Stapled to the car??? [Re: 300by500] #606989
03/12/12 09:45 PM
03/12/12 09:45 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
My 65 Satellite has staples across both front and rear windows. About 30 of them.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Factory Vinyl Top - 70 Coronet - Stapled to the car??? [Re: moparmarks] #606990
03/12/12 09:59 PM
03/12/12 09:59 PM
PEI Canada
chromedome426 Offline
PEI Canada
My 68 Coronet had a couple staples in each upper corner of the front and back windows.
Legendary Interiors recommends using 3M Super Trim Adhesive.
Re: Factory Vinyl Top - 70 Coronet - Stapled to the car??? [Re: mity225] #606991
03/13/12 08:27 AM
03/13/12 08:27 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
12 cans of 3M
Spray top and roof of car
follow directions do not get in hurry, let it get tacky to dry
get it right first time
work in sections
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
