Anyone make a GOOD Aluminum H2O pump?? #606433
02/06/10 09:04 PM
02/06/10 09:04 PM
Warrenton, VA
65Coronet7165 Offline OP
Warrenton, VA
There was a discussion on the C Body Dry Dock board not long ago about aftermarket aluminum water pumps for big blocks. Seems the stuff out there does not do as good a job of cooling as the OEM cast iron pump does. I started a similar thread on that forum. So far, I found out that Mopar Performance makes an aluminum pump that is a similar design to the cast iron one. Looks like that might be the best bet...Thought I'd ask you guys as well...
I've got a 67 300 'vert with the 440 High Po engine and it does not have A/C. She kinda runs hot in the summer when stuck at traffic lights, so if I decide to replace the pump with an aluminum one, it has to perform as well or BETTER than the OEM big block pump.
Re: Anyone make a GOOD Aluminum H2O pump?? [Re: 65Coronet7165] #606434
02/06/10 09:54 PM
02/06/10 09:54 PM
AndyF Offline
AndyF  Offline
The Edelbrock pump should work fine. Milodon also makes a water pump for the big block.
Re: Anyone make a GOOD Aluminum H2O pump?? [Re: 65Coronet7165] #606435
02/06/10 09:57 PM
02/06/10 09:57 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Been using a Flow Kooler pump on my 440 for years now and even with under drive pulleys its been ok.
26 inch radiator,clutch fan,stock shroud,160 thermostat,346 heads,3600 stall conv,3.91 gears
Re: Anyone make a GOOD Aluminum H2O pump?? [Re: jvcuda] #606436
02/06/10 10:01 PM
02/06/10 10:01 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have not seen an Edlebrock BB pump in person, but I do own their small block version and the blade design is very different from a stock pump. Even the Milodon pump looks very close to an oem pump.
If you buy an edlebrock pump be sure to pick up a hi-flow t-stat to go with it.
Re: Anyone make a GOOD Aluminum H2O pump?? [Re: 65Coronet7165] #606437
02/06/10 10:15 PM
02/06/10 10:15 PM
any possibility it's an airflow problem rather than coolant flow?
Re: Anyone make a GOOD Aluminum H2O pump?? [Re: RapidRobert] #606438
02/06/10 10:58 PM
02/06/10 10:58 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
I haved used the Mopar Performance Big Block aluminum housings on quite a few of my cars. You also want to check your pump itself. Someone else can correct me here but I am pretty sure I have seen them with different number of blades on the pump itself?
I may be wrong but they may be different flow pumps?
Joe Sr.
Re: Anyone make a GOOD Aluminum H2O pump?? [Re: joewhite440] #606439
02/06/10 11:07 PM
02/06/10 11:07 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
The OEM pump for a/c cars has more fins. Thats what we use on all BB mopar motors. Works great and you can get them at any parts store.
Re: Anyone make a GOOD Aluminum H2O pump?? [Re: Dougsmopars] #606440
02/07/10 12:26 AM
02/07/10 12:26 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Stock pump does the job for mine and thousands of other big blocks out there.
Re: Anyone make a GOOD Aluminum H2O pump?? [Re: 65Coronet7165] #606441
02/07/10 09:17 AM
02/07/10 09:17 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Eddy pump is a more modern design (cast iron wheel with curved fins). It's also more expensive.
Re: Anyone make a GOOD Aluminum H2O pump?? [Re: torkrules] #606442
02/07/10 10:21 AM
02/07/10 10:21 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
overheating at lights is more than likely NOT a waterpump issue. It's more likely an airflow issue. Do you have a fan shroud? If not then get one.
Don't be the exception.
Re: Anyone make a GOOD Aluminum H2O pump?? [Re: Supercuda] #606443
02/07/10 05:02 PM
02/07/10 05:02 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I use GMB brand big block water pumps.
Re: Anyone make a GOOD Aluminum H2O pump?? [Re: scatpacktom] #606444
02/07/10 08:30 PM
02/07/10 08:30 PM
Warrenton, VA
Warrenton, VA
The issue here is not really about overheating. I've been dealing with the car getting hot at traffic lights during the summer for 3 years now. Right now, I'm thinking of replacing the water pump for other reasons...trying to do my research before I do this..
IF I replace the water pump, I'd like to get an aluminum one to save some weight. There was a discussion on Al water pumps on another forum...seemed like most posters did not think the Al pumps (aftermarket) were as good as the stock cast iron pump.
So my question is simple, despite all the words...IS there an Aluminum water pump out there that FUNCTIONS as well or better than the stock OEM cast iron pump....on Big Blocks..
That's it!!!
Re: Anyone make a GOOD Aluminum H2O pump?? [Re: 65Coronet7165] #606445
02/07/10 09:48 PM
02/07/10 09:48 PM
Dougsmopars Offline
Dougsmopars  Offline
Your only looking at a couple of pounds difference in weight. The AL pumps aren't that much lighter then stock cast one's. Not worth the difference in price and most don't do the job as well.
Re: Anyone make a GOOD Aluminum H2O pump?? [Re: Dougsmopars] #606446
02/07/10 09:52 PM
02/07/10 09:52 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
GMB is alum
