Thermo - BOG!!! #60550
05/20/08 08:57 PM
05/20/08 08:57 PM
Anonymous OP
Anonymous OP
I got this shiny new rebuilt ThermoQuad from a rebuilder who gets mentioned fairly commonly and has a nice website, offers lots of TQ services, etc, etc.
CanNOT get it to idle and come off what passes for an idle. Once over the hump, the car runs like a scalded a** ape.
I've been thinking vacuum leak, but can't find one with the rubber hose :stethoscope trick. Can't change the idle spraying carb cleaner around the carb base. I've tried resetting the idle bleeds everywhere from 1.5 to 3.0 turns off their seats, and all I get is a "hunting" idle, that gradually gets worse as the engine warms up. Then eventually it stalls.
I did a search of the site, and found some folks who are actually running ThermoQuads, so I'm hoping that by way of a "welcome to the club" one of those folks might have a tip or two for me.
I have several TQ reference materials, the Vaanth paper, and the 1974 Factory Service Manual, but There is something I am missing. Help, please!
And THANKS!!!
Re: Thermo - BOG!!! #60551
05/20/08 09:25 PM
05/20/08 09:25 PM
Anonymous OP
Anonymous OP
Probably the fast idle cam is out of adjustment. I have an actual Chrysler Thermoquad service manual that is more in depth than most anything (1982). I will try to get it scanned and into a .pdf tonight, it is about 45 pages.
It could be numerous things all together, needing minor adjustments for each. I have found the t-bog to be a very finicky carb, but once set, very good.
Re: Thermo - BOG!!! #60552
05/20/08 09:34 PM
05/20/08 09:34 PM
Willoughby Hills, Ohio
gd9704 Offline
super gas
gd9704  Offline
super gas
Your rebuilder is a good guy--e-mail him or pm him and he will help you dial in your shiny "new" TQ.
Re: Thermo - BOG!!! #60553
05/20/08 10:05 PM
05/20/08 10:05 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I just printed out the '72 manual. I haven't had a chance to read it yet.
Maybe you have a whoppin big cam?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Thermo - BOG!!! #60554
05/20/08 10:13 PM
05/20/08 10:13 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I had one like that I rebuilt it and put it on the car and it was perfect, the next day it ran just like what your describing. After screwing around with everything I found where a dirt dobber had started building a nest on top of the air bleads, cleaned them out with a pin and it has been running great for 2.5 years. Just something to look at.
Did the motor run fine previously with a different carb?
Re: Thermo - BOG!!! #60555
05/20/08 10:16 PM
05/20/08 10:16 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
And THANKS!!!
Sounds like a vacuum leak that gets worse with heat. Perhaps something is heating up and expanding increasing the leak.
Intake gasket? Carb base gasket? Base warped?
Did the engine run fine with a different carb on it before? Was the intake swapped?
Doc.
Re: Thermo - BOG!!! [Re: NTOLERANCE] #60556
05/20/08 10:37 PM
05/20/08 10:37 PM
Anonymous OP
Anonymous OP
i don't see the proper gasket under that BAD BOY carb.
Re: Thermo - BOG!!! #60557
05/21/08 12:14 AM
05/21/08 12:14 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Contact your builder. If it's the same thermoquad guy I praise, I have no doubt he'll solve your problem and get you up and running like a champ. TQ's are great carbs once you get them dialed in.
Re: Thermo - BOG!!! [Re: DaytonaTurbo] #60558
05/21/08 12:30 AM
05/21/08 12:30 AM
Anonymous OP
Anonymous OP
Some of the dialing should be done on car though...
Re: Thermo - BOG!!! #60559
05/21/08 12:41 AM
05/21/08 12:41 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
Far as base gasket setup goes I prefer to run the thick 3/16"-1/4" gasket sandwiched between the two thin gaskets. Good added insulation from heat soak and no vacuum leaks with this setup.
Using a TQ carb is definitely a love/hate relationship. At the moment I'm in love with mine but that could change any time.
Actually I've run one for about 4 years now and it runs great on my 340 combo. Bought the rebuilt carb off of Ebay and tweaked it for my combo with big squirters and secondary jets.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Thermo - BOG!!! [Re: MY340] #60560
05/21/08 03:51 AM
05/21/08 03:51 AM
Anonymous OP
Anonymous OP
Re: Thermo - BOG!!! #60561
05/21/08 05:46 AM
05/21/08 05:46 AM
places
79powerwagon Offline
places
If you are referring to builder David, he will help you out. When he built one for me, I had all kinds of unexplainable issues, and David spent about 100 hours on the phone with me walking through every conceivable possibility. He is one of the good guys! But he is also human, and as soon as the human factor is added to the equation, there is always the possibility of an error. He will work with you!
Re: Thermo - BOG!!! [Re: 79powerwagon] #60562
05/21/08 08:22 AM
05/21/08 08:22 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
On my TQ 1.5-3 turns out on the idle screws is nothing.
When you get it running, press down on the accel pump arm and let the spring shoot fuel without touching the throttle shaft.
If it runs better right after the shot, you should back out the idle screws more.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Thermo - BOG!!! [Re: CJK440] #60563
05/21/08 07:16 PM
05/21/08 07:16 PM
Anonymous OP
Anonymous OP
Now, THAT's interesting.... some other comments I'd picked up were telling me that I might already be too far out / too rich. Thanks for another view, and your experience!
Re: Thermo - BOG!!! [Re: 79powerwagon] #60564
05/21/08 07:23 PM
05/21/08 07:23 PM
Anonymous OP
Anonymous OP
Yup, David is my builder! I've gotten good "vibes" from him, and never heard a bad word about him anywhere. The carb sat in my garage for a few months, before I decided to use in on THIS car instead of a future project. Just now, David seems to be a little hard to reach. I'm a patient guy, and if I sound otherwise, it's just frustration. I'm certain it will all work out in time, and I HAVE time!
Re: Thermo - BOG!!! #60565
05/21/08 07:32 PM
05/21/08 07:32 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
So, what baseplate gasket are you using?
How did the engine run before?
You say its been sitting a 'couple of months' without use, was it actually a couple of months, or more like a year?
I could think of a couple of internal issues that would cause hunting, but, you shouldn't have them on a 'fresh' carb.
Along the lines of internal issues, what kind of gas are you using? Any additives? (thinking maybe a gasket was damaged by chemical reaction).
TQ's aren't that hard once you get over the initial fear of the unknown.
For that matter, how much experience do you have working on any carb??
Hope I haven't asked too many questions.
John
Re: Thermo - BOG!!! [Re: SattyNoCar] #60566
05/27/08 07:28 PM
05/27/08 07:28 PM
Anonymous OP
Anonymous OP
I'll answer your questions in reverse order.
#4: Not much. I've swapped out and set idle mix and base idle on probably a half dozen "stock replacement carbs over thirty odd years. swapped out the TQuad on my '74 dodge motorhome's 440 for a rebuilt from a generic auto parts house about five years ago. Bolted it on, hooked up the hoses and drove it, but that's the only TQ I've ever laid tools on.
#3: regular 87 octane pump gas (Shell, I think) with no additives).
#2: From the date of my last emails to and from David, I got the carb right around Christmas last year, so call it five months on the shelf.
#1: The engine ran "OK" with the eddy 1406. No off idle stumble or flat spots. With the tranny kickdown linkage FUBAR, I hadn't pushed the car really hard, but a couple of times, for fear of damaging the tranny. With no kickdown functioning, acceleration was less than thrilling on the street, but "adequate" on the hiway.
The performance with the TQuad IS thrilling, once I get it past the bog. When the the engine starts to wind up, and the secondaries open wide, i LOVE the moan/howl! The kick in the pants when the tranny kicks down is a HOOT after three years of no such luck. Now if i could just get it to idle down, and come off idle like it comes on the secondaries I'd have a PERMANENT grin from ear to ear!
Re: Thermo - BOG!!! #60567
05/27/08 09:49 PM
05/27/08 09:49 PM
Anonymous OP
Anonymous OP
Re: Thermo - BOG!!! #60568
05/27/08 10:05 PM
05/27/08 10:05 PM
SattyNoCar Offline
SattyNoCar  Offline
A post back from the dead......
I'll chime back in tomorrow when I have more time.
Too bad you're in South Austin instead of Houston.......
John
Re: Thermo - BOG!!! #60569
05/28/08 12:03 AM
05/28/08 12:03 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
...I've been thinking vacuum leak, but can't find one with the rubber hose :stethoscope trick.
Any chance you've got cracked/damaged vacuum line or intake leak? Have you put a vacuum gauge on it to see what the manifold vacuum is doing?
Does adjusting the air/fuel screws change the idle at all?
Welcome to the TQ club!
If you give the metering rod tree screw a 1/2 turn clockwise, does your idle improve?
