Re: 383 to 440(69 superbee)
[Re: 1hirschdalemopar]
#604283
02/06/10 11:57 AM
02/06/10 11:57 AM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
Thanks guys,now I am on the right track,just have to see if I can make the rpm intake work.I am not scared to make my own base if possible.
I think this is the right approach. When you get to this point, you'll figure something out to make it work.
![](http://sitebuilder.yola.com/sites/Da9b/D1fa/Dcca/Df0c/U8a49866a1daeda61011dc0faccaf1b9a/8a4986c81daed352011dc18073f264c7/resources/DSC05040.JPG)
[Re: jhayes63]
#604286
03/26/11 11:35 AM
03/26/11 11:35 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
I've got a 1969 383 Super Bee with the ramcharger setup. Currently it has a 1965 dated 383 with an Edelbrock intake and carb. The carb sits almost an 1" higher, so I took a repro base and shaved the bottom opening that sits on the carb until everything fit. I didn't have any issues with lines off of the carb or fuel linkage. Now I'm thinking about putting in a proper year 383 or 440. Did you get your 440 to work with the Ramcharger? I would be interested in hearing how your project ended up! And any insights into switching to a 440 with the ramcharger. Thanks!
The ductwork on the hood does not care what engine is under it , it's the same pieces , with a cutout for master cylinder clearance for the hemi engine also. what you found out is the air cleaner height is the deciding factor. you can put a 440 in there but be careful with manifold selection , you will have to modify that air cleaner you have more to kep it from hitting the hood .
[Re: jhayes63]
#604288
03/26/11 07:34 PM
03/26/11 07:34 PM
JohnRR
Thanks! I wasn't sure if the carb would be more forward or to the rear to where it wouldn't fit into the ramcharger. I figured I could accomodate the difference in height as long as it wasn't too much. It seems like it would be ok.
The carb is in the same location front to rear/side to side.
[Re: JohnRR]
#604289
02/27/12 05:44 PM
02/27/12 05:44 PM
Posts: 4,799 ILL
MLR426
ILL
I realize I'm talking a 383 B engine and not to a 440 but so many have responed to this post I figure it was a good place to put since I wouldn't be hi jacking a current post. It's been a while so I thought I would ask and get it started back up. I'm now in this same funk!! I'm building a 512 stroker 400 base engine and the customer wants to keep his freshly restored and painted Ram Charger hood. But with limited choices of intakes, the engine will suffer performance and be bottle necked at the intake. What is the best intake selection with at this time to fit under the 69 superbee fiberglass, I know a 100 plus horsepower loss is coming...with the intake if the customer doesn't change his mind. I would like to use the 383 Torker 2. What is the difference in intake heights from Torker 2 to stock magnum 4 barrel ?
logan426
