turbo 400 chrysler install ? #604228
02/04/10 09:20 PM
02/04/10 09:20 PM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
Hi, Was wondering if anyone on here has put a turbo 400 in a A body and if they know how much of a pain it will be.
Have trans,Ultra bell,conv. Fresh
Had a MASSIVE 727 explosion may 2008 and have not been back since.Fell beter now and getting ready to go again.
I have a 72 demon.493 pump gas motor,exhaust and drag radials.Car goes 10 teens in the heat.Went through 7 torque flights! No Junk Either!
Last 2 were ATI! Brand New! The Last 1 nearly blew my foot off.with a blanket.Drum explosion Nothing left of the trans.Broken foot and tore the ligaments off of my ankle,and had destoyed arch! I am still walking and ready to race again.
Ok not trying to cry but I am done with 727's everyone says they can build one that won't blow up.Others sell you one done and it blows up and does not have the parts in it that you payed for.
So any info on the turbo deal would be much appriciated. Thanks Tom
Re: turbo 400 chrysler install ? [Re: grncpe] #604229
02/04/10 09:31 PM
02/04/10 09:31 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
good luck with your trans - i just gotta say that you never had an aftermarket drum in there otherwise it would not have exploded - sorry to hear and hope you recover fast!
Re: turbo 400 chrysler install ? [Re: DJVCuda] #604230
02/04/10 11:37 PM
02/04/10 11:37 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
The T-400 is a great racing transmission and you can not argue with results and track records.
Drop one in your car and don't look back.
Who cares if it does not fit .... make it fit and you are done ..
There is a reason why the majority of racers don't run mopar or ford trans, its because the glide and the 400 work.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: turbo 400 chrysler install ? [Re: go green] #604231
02/04/10 11:51 PM
02/04/10 11:51 PM
Utah
topbrent Offline
topbrent  Offline
Utah
_
Re: turbo 400 chrysler install ? [Re: topbrent] #604232
02/05/10 12:16 AM
02/05/10 12:16 AM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
Just trial fitted one for my duster.Looked like the governor cover was going to hit the frame crossmember,but my trans guy said you could filp it inside out or make a flat cover if it was full manual and didn't use the governor.I'll start on it again when it warms up some and let you know.
Re: turbo 400 chrysler install ? [Re: grncpe] #604233
02/05/10 12:21 AM
02/05/10 12:21 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
I went with a Glide, was so easy,
even a caveman can do it
Re: turbo 400 chrysler install ? [Re: topbrent] #604234
02/05/10 12:22 AM
02/05/10 12:22 AM
Missouri
galen Online content
galen  Online Content
Missouri
I put a 4L80 behind my big block in a B body. I had to do minimal trimming. I fabbed a new rear crossmember. Had to cut and move the right collector on my underchassis TTI headers. I have a wilcap and a TCI adapter. Chrysler mini starter in stock location. Turbo 400 is a little smaller than the 4L-80. All in all a pretty easy conversion. Galen
Re: turbo 400 chrysler install ? [Re: grncpe] #604235
02/08/10 09:30 PM
02/08/10 09:30 PM
Kingsville, Md
grncpe Offline OP
grncpe  Offline OP
Kingsville, Md
Thanks everyone for the info.I guess when I dig out from the snow I will get started.My big concern also is the header clearence.I have CPPA in the chassis 2" headers.Very tight with 727 I think it may be easyer to make the trans. tunnel removable so I can drop it in from the top.The 727 was a nightmare with a blanket on it to put in and take out.I am not sure how this 400 will work with a normal gm trans shield.So any added info will be much appriciated.....
Thanks Tom
Re: turbo 400 chrysler install ? [Re: grncpe] #604236
02/08/10 09:42 PM
02/08/10 09:42 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
lots of successful 727's out there that stay together especially in a 10.0 car.
i've done everything wrong that you can do to 727 and mine is still going strong
best thing is it fits like it was made for the car
keep it all mopar
by the way mine is done by John Cope at CRT
either way good luck
WAXER
Post deleted by Defbob [Re: B1KILLER] #604237
02/08/10 09:50 PM
02/08/10 09:50 PM
Re: turbo 400 chrysler install ? #604238
02/08/10 10:41 PM
02/08/10 10:41 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
My turbo 400 that will be backed my a MOPAR trans
Re: turbo 400 chrysler install ? #604239
02/08/10 10:42 PM
02/08/10 10:42 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
LOL Fred
Re: turbo 400 chrysler install ? [Re: Jeepmon] #604240
02/08/10 10:52 PM
02/08/10 10:52 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
WHY????
990hp 499 lowdeck here. A "we" built 727 with good parts. Will be going on its 7th year this year. NO PROBLEMS and leaves with the wheels in the air every run.
Re: turbo 400 chrysler install ? [Re: grncpe] #604241
02/08/10 10:56 PM
02/08/10 10:56 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
557 " RBRE / KB Hemi with 'Glide....EASY !
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: turbo 400 chrysler install ? [Re: chryco] #604242
02/10/10 02:32 AM
02/10/10 02:32 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
It was Chryco & others who talked me into my glide... that and the price, weight, parts option, parts cost & availability, $3500aud on my door for a brand new full house transbraked trans with two brand new converters, JW ultra bell & JW "the wheel" flex plate, came with a full print out & writen warrenty for up to 800hp, here in Aust you just can't get that in a 727. the JW ultra tail is a new addition... next is a JW ultra case
Re: turbo 400 chrysler install ? [Re: SG duster] #604243
02/10/10 08:58 AM
02/10/10 08:58 AM
Pottstown, Pa.
sg1093 Offline
sg1093  Offline
Pottstown, Pa.
Just because the trans was built by ATI does not make it good. I have a ATI converter in my car that broke in 47 runs, got it fixed and is ok now. But I would never have ATI build me a transmission. If you feel more confortable with a 400, ok, but they can explode too. There are better sprags and drums for the 400 that probably should be installed. I installed a Powerglide in my 70 Dart to race Super Street which was not bad, but I am sure the dimensions on a 400 are larger. Then you must fit for a shield or blanket.
Re: turbo 400 chrysler install ? [Re: sg1093] #604244
11/05/11 10:39 PM
11/05/11 10:39 PM
Wisconsin
roadguy67 Offline
roadguy67  Offline
Wisconsin
JW Performance will be offering a Turbo 400 with an ultra case and ultra bell making it possible to bolt a turbo 400 directly to Mopar block (no adapter mid-plate).
The case and the bell are SFI certified so no additional shields will be needed.
http://www.racewithjw.com/
http://www.campbellenterprises.com/turbo-400-transmission-parts/th400-ultra-case-jw-32310.php
Re: turbo 400 chrysler install ? [Re: joshking440] #604245
11/06/11 09:12 AM
11/06/11 09:12 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
That thing looks absolutely scary @$$ wicked.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: turbo 400 chrysler install ? [Re: joshking440] #604246
11/06/11 09:33 AM
11/06/11 09:33 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
EDIT
This was backed by a Mopar trans and I switched to a Turbo 400 to back my turbo'd 400!!!! my 727 didnt make it.....as everyone told me!!!
Re: turbo 400 chrysler install ? [Re: ChrgrCuda] #604247
11/06/11 09:34 AM
11/06/11 09:34 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Thanks man!!!
