5.2/5.9 Magnum roller lifter limits #602676
02/03/10 06:27 PM
02/03/10 06:27 PM
Manitoba, Canada
O
Overdrive440 Offline OP
O
Manitoba, Canada
What are the known limits to stock mopar magnum lifters with respect to lift and spring pressures?
Re: 5.2/5.9 Magnum roller lifter limits [Re: Overdrive440] #602677
02/03/10 10:53 PM
02/03/10 10:53 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
At about .375" lobe lift, they will want to fall out of the dog-bone so we usually keep the lobe lift to around .360" with the magnum stuff. We've ran ~660lbs. over the nose using a factory magnum lifter that we "made" solid.
Re: 5.2/5.9 Magnum roller lifter limits [Re: SuperStocker] #602678
02/04/10 06:05 PM
02/04/10 06:05 PM
Manitoba, Canada
O
O
Manitoba, Canada
Would this still be the case with the Mopar Magnum Race blocks with the Mopar tappet retaining kit P5155275?
Re: 5.2/5.9 Magnum roller lifter limits [Re: Overdrive440] #602679
02/04/10 09:38 PM
02/04/10 09:38 PM
Vacherie, Louisiana
super gas
super gas
Vacherie, Louisiana
I'm not sure as our stuff was all factory production.
Re: 5.2/5.9 Magnum roller lifter limits [Re: SuperStocker] #602680
02/01/11 06:29 PM
02/01/11 06:29 PM
Manitoba, Canada
O
O
Manitoba, Canada
What about if one would use Crane 70530-16 lifters? apparently these are supposed to be a bit taller than stock (according to their description).
Crane's web page
Re: 5.2/5.9 Magnum roller lifter limits [Re: Overdrive440] #602681
02/01/11 07:27 PM
02/01/11 07:27 PM
Manitoba, Canada
O
O
Manitoba, Canada
Never mind the above statement... read through their entire product bulletin (after I finally found it), and it looks like the extended travel replacement lifters are for chevy only.
