can a 71 cuda road lamp relay be used in a 70 cuda ?
#602487
02/03/10 02:53 PM
02/03/10 02:53 PM
Posts: 100 Sarnia ON / PortHuron MI
SCHU
Can a 1971 cuda Road Lamp Relay (4 terminal) be used to plug in and safely work on my 1970 cuda using its factory 70 cuda wire harness ? I could not find a repro 70 Relay but Evan’s sells the 71 style. I know the 71 Relay has 4 terminals and the 70 Relay has only 3, but the harness plug configuration is similar and can plug the 71 relay directly into the 70 harness but there will be an extra single terminal left on the other end of the 71 Relay unused . Please reply ONLY if you are sure and have actually done this before,I don't want to damage anything under the dash. What will I need to do to the single extra terminal on the opposite end of the relay for safety ? thanks SCHU , dougandcindy@sympatico.ca
Re: can a 71 cuda road lamp relay be used in a 70 cuda ?
[Re: screamindriver]
#602493
02/06/10 01:52 PM
02/06/10 01:52 PM
SCHU
the 70 relays are out there...Just saw 2 doing a quick search on E-bay...
I see an NOS on Ebay for almost $400 & a while ago a used for $150 which they won't guarantee it works or willing to test, too much to spend on a used electrical part that may or may not work. I hope Evan's or another will repop a new`70 for the same price as Evan's `71 relay which is $90 which is guaranteed to work as it is a new part. Until this happens, I hope someone can tell me if the `71 can be connected safely to 70 harness, even if I need to make a short adapter with my connecters to use, so I can use new 71 from Evan's . My 70 cuda is not a high dollar show only car, I just want to cruise/drive it will all switches functional as stock. Hope someone out there has tryed the relay swap, or can electrically map out the 71 relay. thanks Doug.
[Re: SCHU]
#602494
02/06/10 01:58 PM
02/06/10 01:58 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
Check with Evans. If they are the same people that make the wiring harnesses, they will know the answer to your question. They should be able to supply a modified cable that will work for your application. Bill & Rose Evans 8835 Parson Rd Erie, PA 16509 Phone 814)864-2622 * Fax (814) 866-8184 rbevans7@aol.com Weekdays: 5pm - 10pm EST Weekends: 12pm - 9pm EST
#602496
02/06/10 03:22 PM
02/06/10 03:22 PM
Posts: 636 SE PA
cudaize
SE PA
It is my recollection that the only electrical reason the relay needs to be on the 70 harness is to operate the headlamp delay circuit should your car have it. I believe the 70 roadlamps will work fine without the relay plugged in unless you have the delay circuit. 71 has the relay to toggle the roadlmaps off when high beams are turned on. Mike Afflerbach Cudaize@comcast.net
