Re: More about scheduled / estimated production dates......
[Re: 70gtx440dana]
#601345
03/03/10 01:34 AM
03/03/10 01:34 AM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Very possible. I have mostly been looking at 1970 Hamtramck cars, but I would like to see scans of the sheets you found if possible? If you have not contacted him yet, I am sure that Chris at the 1970 Charger Registry would like to see them too.
[Re: Alaskan_TA]
#601346
03/20/10 12:42 AM
03/20/10 12:42 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
First time I have seen this scenario. Same plant. Same model. Identical options except for the ones that affect color. Sequential VINs. Sequential VONs. different scheduled production dates I have no clue what it means, but pretty dang cool to see. Thanks to Bill in CA for sending these to me.
[Re: hemibill]
#601348
03/20/10 01:29 AM
03/20/10 01:29 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
The broadcast sheet for 985 was in with the stuff you sent also, it is not coded as a sales bank car or as an ordered car. I see that a lot. Just strange (and cool) that these two have different dates. Yes, I do know I need to get out more. Barry
[Re: Alaskan_TA]
#601349
03/20/10 01:49 AM
03/20/10 01:49 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
I agree that it is cool to see 35 years later, but I'd "assume" there will be a last car & first car scheduled every day and more often than not their VIN#s will be sequential.
Has anyone ever seen any numbers showing "sales bank" VS. "SOLD" car production numbers?
[Re: 6bblgt]
#601350
03/28/10 01:53 AM
03/28/10 01:53 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I just thought it was interesting that it caught my eye that on the second tag, the font was stamped much higher up than the first tag. was this a "tag placement in the machine" thing, or it was set each day and all tags from that day would be stamped in the same location?
Maybe this is a very common thing, but to have the two consecutive tags next to eachother, I noticed it quickly.
[Re: Alaskan_TA]
#601353
06/02/10 12:08 PM
06/02/10 12:08 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
Possible for sure.
Tracking a cars dates codes can be educational too. My T/A has a SPD of 417. The original engine has a final assembly date five days later, so my car was likey made at least 6 days late.
My 69 Bee has an SPD of 2/10 , the original engine was assembled on 2/11
[Re: Furyman]
#601355
06/02/10 05:58 PM
06/02/10 05:58 PM
Posts: 1,109 Hiram, Georgia
474218
Hiram, Georgia
True production dates are guesswork at best.I'd say for the majority of Mopars the true date is +/- 2 weeks of the date stamped on the fender tag; excluding package cars that use a common date ie A12's.This early 69 Fury is a good example.The SO # in the upper right corner is 803...this is the date stamped on the fender tag.The car was actually shipped to the dealer on 8-16.The scheduled date is 7-25.....I'm not positive but I think this is the date that the car was actually scheduled to have been shipped.?? Ideas? One thing for sure...for the most part VIN's and the date stamped on fender tags run hand in hand.Example: the above poster with the St Louis B Body with the B08 date...Vin # will be in the 9G162xxx to 9G163xxx range.Again excluding package cars...440 Darts,A12's etc this is nearly always true but every once in a while there is a wild car(d).
Not to hijack the subject but checkout the........
A01 LITHT PKG?
[Re: burdar]
#601357
08/19/10 04:56 AM
08/19/10 04:56 AM
Posts: 6,301 colorado
a12superbee
colorado
The 927 and 10-72 would make it an early (er) car, as the model year starts in august.
I can't afford this.
mark
[Re: Alaskan_TA]
#601362
10/03/10 10:49 PM
10/03/10 10:49 PM
Posts: 21,519 N.E. OHIO, USA
A12
N.E. OHIO, USA
FWIW, I was told by D.ick Maxwell that Production Planning and Fleet Engineering collaborated on a lot of production line issues. Their job was to “Keep the line moving” and if there were delays of components or unscheduled rush order (i.e. the seven police cars), order cancellation, late decision to introduce a new model or sales program (i.e. A12, A13, “Spring Special”, etc.) then that bumped or move a cars SPD forward or back. At the time of the order it is only a “Scheduled (planned) Production Date and lots can happen between those dates. The A12’s had issues with intake manifolds from Edelbrock and I’m sure that had some affect on the SPD and then I heard some A12’s were bunched up because of the lift-off-hood production, they were not shipped one hood at a time and needed “special handling”. I guess it should have been called PSPD for “Planned” Scheduled Production Date. On a related note I ordered two trucks from Ford a few years ago and was given a mid-January SPD and went ahead and scheduled High Tech Trailers to have them painted at the beginning of February and then scheduled the graphics company to do the graphics at the end of February when the paint had a little time to set up. Ford had delays with the new diesel and then more delays and we finally got the two trucks at the beginning of APRIL!!! They still had the mid-January SPD, so it still happens to this day, it’s only a planned date for production and when Chrysler started assembly of the chassis in Body-in-White the fender tag was made and at that point they had a “plan” to build and finish the car by or around the SPD but who knows what the date was when the tag was punched? What do you think Barry?
MikeR
