Re: Duplicolor Engine Enamel Paint - spray can [Re: Pacnorthcuda] #601048
02/05/10 02:31 AM
02/05/10 02:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This is Dupli-Color thats been on my 63's eng for 4 years and holding up fine so far. The Mopar Hemi orange was junk as half the cans dont work and when they did it was like spraying water on the eng. Ron
Re: Duplicolor Engine Enamel Paint - spray can [Re: Rob440Magnum] #601049
02/05/10 09:44 AM
02/05/10 09:44 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Ok, thanks for the responses. My intake is already painted with duplicolor in Chrysler Orange about 5 days ago.
Question:
What prep work should I do to spray with plastikote clear to enhance gloss and shine?
Should I scuff with a scotchbrite, should a spray a coat or two of color by plastikote before I clear? Suggestions?
Thanks, Rob
Don't spray it with clear over Duplicolor. You will still have the wrong color. If you are going to the trouble of getting the existing color ready for clear just shoot Plasticoat color.
Wipe everything with laq. thinner and shoot it.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Duplicolor Engine Enamel Paint - spray can [Re: MOPARMIKE69] #601050
02/05/10 01:25 PM
02/05/10 01:25 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Do they still make Plasti-coat? All I ever see is Dupli-color which is ok I suppose...
My Plasti-coat finish on my 318 has been there for 10 years
Re: Duplicolor Engine Enamel Paint - spray can [Re: Rob440Magnum] #601051
02/05/10 02:12 PM
02/05/10 02:12 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: Duplicolor Engine Enamel Paint - spray can [Re: autoxcuda] #601052
02/05/10 05:40 PM
02/05/10 05:40 PM
I had a hard time tracking it down locally as well.
I went to the local Car-Quest auto parts store and they ordered some for me.
Re: Duplicolor Engine Enamel Paint - spray can #601053
03/18/10 10:50 PM
03/18/10 10:50 PM
Williamsport, PA
Rob440Magnum Offline OP
mopar addict
mopar addict
Williamsport, PA
Thanks for the help. Below is what I ended up doing.
1. scuffed the duplicolor paint that I applied weeks ago with a scotchbrite pad to help promote better adhesion
2. two med-heavy coats plastikote Chrysler orange engine enamel
3. two med-heavy coats plastikote clear engine enamel
Results are absolutey WOW! The shine is amazing and exactly what I was looking for. On a scale from 1-10 the I would rate the Duplicolor a 3, and the Plastikote color followed by clear a 10.
Thanks everyone for your input, Rob
Re: Duplicolor Engine Enamel Paint - spray can [Re: Rob440Magnum] #601054
03/19/10 12:18 PM
03/19/10 12:18 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
I noticed the OP said he is painting a aluminum intake.
In my experience bare aluminum is more porous and the paint soaks in and look less glossy. You'll have to put on more coats on the aluminum to build up the surface to match the cast iron.
Re: Duplicolor Engine Enamel Paint - spray can [Re: Rob440Magnum] #601055
03/19/10 12:32 PM
03/19/10 12:32 PM
CHRGR69 Offline
CHRGR69  Offline
I just finished spray painting my aluminum intake manifold with with Duplicolor high temp engine enamel spray paint in a rattle can.
Is there a way to get this to look more glossy? What if I spray paint with high-temp clear coat by Duplicolor will that add any more shine or gloss?
Thanks, Rob
Do not mean to hijack, but has anyone tried the Duplicolor High temp/heat header black spray paint?
Grandma always said I had "hands of gold"!
Re: Duplicolor Engine Enamel Paint - spray can [Re: CHRGR69] #601056
03/19/10 06:56 PM
03/19/10 06:56 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I did with exhaust manifolds and it worked great. sand blast, wipe down or spray with brake cleaner.
Then spray. When handling use gloves or the oils off your skin might ruin the areas you touch.
Re: Duplicolor Engine Enamel Paint - spray can [Re: demonH1B] #601057
03/19/10 07:03 PM
03/19/10 07:03 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I just painted my motor with Mopar engine paint. Lots of places carry it even Summit. New formula. Not watery. Covered very well. Color looks right on.
Re: Duplicolor Engine Enamel Paint - spray can [Re: Dougsmopars] #601058
08/25/11 12:41 PM
08/25/11 12:41 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Old thread is old but what about VHT? anybody used it?
Re: Duplicolor Engine Enamel Paint - spray can [Re: DusterKrazy] #601059
08/25/11 03:01 PM
08/25/11 03:01 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I've had very good luck with VHT in the past. Color choices are limited though. I think the only Mopar colors are Hemi Orange and maybe Turquoise. No Blue.
VHT is a division of Duplicolor, but seems to be a different formulation than the Duplicolor engine paint.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Duplicolor Engine Enamel Paint - spray can [Re: 471Magnum] #601060
08/25/11 03:17 PM
08/25/11 03:17 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
weird this thread was brought back to life as i was just reading it the other day! i was looking for the 'race' hemi orange (NOT pumpkin colored) and i was hoping to find something i could just walk into a parts store and get - not happening!
Re: Duplicolor Engine Enamel Paint - spray can [Re: mikemee1331] #601061
08/25/11 04:09 PM
08/25/11 04:09 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
