TORQUE CONVERTOR QUESTIONS .... AND MORE...... #598979
01/31/10 12:08 AM
01/31/10 12:08 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Posting for a Magnum-owner friend.
Can you safely remove the weights from a 360 convertor to use on a 340?
Also, who carries that whoopdedoo for your shift linkage which goes over header pipes?
Also, he's installing a 340 with around 400 horsepower, wondering if he should build up his 998 or get a 904/727 and build it up?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: TORQUE CONVERTOR QUESTIONS .... AND MORE...... [Re: Magnumguy] #598980
01/31/10 12:41 AM
01/31/10 12:41 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
yes..you can remove the weights..
what is the trans going to be used in?
904/999 are basically the same trans..except 999 can have extra clutch disc and steel plantitaries and could have different first gear and/or second gear ratios.
Tony
70 AARCuda Vitamin C
Re: TORQUE CONVERTOR QUESTIONS .... AND MORE...... [Re: 70AARcuda] #598981
01/31/10 02:33 AM
01/31/10 02:33 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Yes , I'm going ahead with my 999 behind a 408 stroker....first gear is lower 2.74 and steel planetary as mentioned.....called the guy at SMR transmission, did not try to bul**** me with stuff.....
Also the 999 have 5 disc clutch instead of 4
basic upgrade with not too much expensive parts..
good for 450+ hp..
Dan
