Distributor Pickup plate(coil) #596650
01/28/10 06:34 PM
01/28/10 06:34 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Have a 360 that seems to love to eat the distributor pickup plate(coil). Sometimes they will last a month, other times last a year, any ideas of what could possibly be causing this? The car originally had the stock Chrysler ignition box, but have since switched over to a MSD 6AL.
Re: Distributor Pickup plate(coil) [Re: DusterKid] #596651
01/28/10 06:36 PM
01/28/10 06:36 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
eat it up how? are the windings opening up like it burnt out? or shorting together
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Distributor Pickup plate(coil) [Re: aarcuda] #596652
01/28/10 07:03 PM
01/28/10 07:03 PM
Keymar, MD
Keymar, MD
guessing burn out...won't allow the spark plugs to fire (spark)
Re: Distributor Pickup plate(coil) [Re: DusterKid] #596653
01/28/10 08:24 PM
01/28/10 08:24 PM
Truckville, the capital of NY
85_Ram_4speed Offline
Are you setting the air gap on the reluctor/pickup each time? Should have ~.008" and set with a brass feeler gauge.
Outcast Dodge guy.
Re: Distributor Pickup plate(coil) [Re: DusterKid] #596654
01/29/10 10:20 AM
01/29/10 10:20 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
get an ohmmeter and measure its resistance (of a bad one)
