engine oil
#596542
01/28/10 02:47 PM
01/28/10 02:47 PM
Posts: 23 Ontario. Canada
hemidere
Ontario. Canada
Based on experience, what brands of engine oil are other members using on their daily driven flat tappet engines. I just read about oils with API service rating of SM are not sutable on older engines with high lift cams and heavy spring rates. Any suggestions are greatly appreciated.
Re: engine oil
[Re: 05dakota]
#596549
01/30/10 09:40 AM
01/30/10 09:40 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
I've run Royal Purple for years. I ran it in my 73 Dart with a flat tappet motor, hyd first and then to a solid. I run it in my Powerstroke truck, my hyd roller motor now, my golfcart, my kids 4 wheeler, my generator, my lawnmower etc. I even used to run it in my Harleys. It really kept the harley engines cooler when we were riding in parades (Shriner). I even had it in my 65 VW Manix street dune buggy. I have never had an oil related failure. I lost a solid flat tappet a long time ago with an oil failure with Castrol. That caused the switch and I've been happy since. ![](/ubbthreads/images/graemlins/Twocents.gif)
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
