Re: 1964 Hemi hardtops
[Re: 64Post]
#595368
01/27/10 02:34 PM
01/27/10 02:34 PM
Posts: 609 Sometimes Northern California,...
LO23M8B
Yes, my book doesn't have any dealer codes for the lightweights or the all steel cars. You know my car ended up in South Carolina, that is where the previous owner found it. Sold in Chicago and ended up in South Carolina. Also, mine was number 17 in the build of 35..right in the middle. You would have thought that more cars than that went to the racers in the south. Would they have sold it out of Chicago to a racer in the South? I wish we had more information on these cars, becuse they sure have a lot of unusual stuff about them.
64 S/S Hemi Plymouth, 1963 4-Door (13.5-1) Max Wedge Savoy, 69-440 Dart 10.20 et 132 mph on the footbrake, 2012 Dodge Ram 2500 turbo diesel, 69-440-6 Roadrunner, 05 Hemi Magnum, 2003 Dodge Ram 2500 P/u, 2005 Viper, 98' Town & Country.
[Re: 64Post]
#595369
01/27/10 02:53 PM
01/27/10 02:53 PM
LO23M8B
Dave, I just went and found a second book that I have and it does show the dealer codes for all the 64' Plymouth hemi cars. They are only showing numbers for the Dealers. Not names or locations. The first book by DD did not have them. Also, this book is only showing Plymouth. I imagine that if you want the Dodge information, you would have to buy the Dodge book. If you want, I could copy and fax the codes to you. Who would have the Master sheet of dealerships? Also, most of the cars went to different dealers according to the codes. It looks like dealers got just one car. They were spread out pretty good.
[Re: 64Post]
#595371
01/27/10 03:20 PM
01/27/10 03:20 PM
LO23M8B
![](/ubbthreads/images/graemlins/iagree.gif) Seems logical to me. My car had a June 23rd ship date. The earliest ship date I can see is June 15th for the vry first vin on the all steel cars. The dealer code for that car is #5104.
[Re: LO23M8B]
#595372
01/27/10 04:12 PM
01/27/10 04:12 PM
LO23M8B
The first book I have is kinda the short version, pocket size, by DD. The 2nd one gives all kinds of good information. It called the Complete guide to the 1964 Plymouth Super Stock III and Super Commando Package by Darrell Davis. Check it out. You can order it off of his website.
[Re: LO23M8B]
#595373
01/27/10 04:49 PM
01/27/10 04:49 PM
Posts: 20,978 A collage of whims
topside
A collage of whims
Like Porsche, the Chrysler codes (A864, A990) are in a numerical order by timeline of creation, not necessarily by sale date or availability. IIRC, the '50s Indy Gen 1 Hemi was an A-311. 864 was the '64 Hemi, 990 the '65 version, but that doesn't explain the variations within the year (NASCAR vs Drag Race spec), which seems vague to me. There was a red/red '64 Belvie 864 Hemi that showed up in a few magazines in the '80s, apparently an original car, and IIRC it was the single 4-barrel NASCAR motor. In '65, when the Melrose Missile was to be converted to the full-on AWB from its 2% version, Chrysler shipped a body in white and boxes of parts to facilitate the conversion, since it was not done at Amblewagon but in Calif.
[Re: RaceCarRegistry]
#595376
01/27/10 08:01 PM
01/27/10 08:01 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
The few that I have seen have had Carter carbs. Some say all early 64's had Carter carbs[A-864]
The little old lady from Pasadena is back!
[Re: KD800X]
#595379
01/27/10 11:49 PM
01/27/10 11:49 PM
Posts: 3,427 PA
PLATINUM6BBL
PA
Were all the steel nosed Plymouth's done as Belvedere's? Back in 83 I looked at a 64 steel nose Hemi Plymouth and I swear it was a Fury. It was a red 4spd car. When I saw it it hadn't been out for a really long time and still in the hands of the second owner who had bought it in 70. The last time I talked to the guy who introduced me to the owner it was still in the same location. It was taking up space w/ a 66 Hemi Satellite convertible and a factory Pontiac race car.
1969-1/2 A12 LOH Road Runner A4 w/ M6S 13.34 at 104 PSMCDR 9/06 in Mopar Action 8/07 12.95 at 105.94 F.A.S.T. 11/06
[Re: PLATINUM6BBL]
#595380
01/28/10 12:21 AM
01/28/10 12:21 AM
topside
A collage of whims
Reed, I think the 2% car was delivered, one of 2 Plymouths & 2 Dodges; I'm not aware of the car ever having a standard wheelbase. I'm referring to the 10"/15" AWB conversion of that body. As a 2% car it had the relocated front suspension & K-frame, clearly visible in photos when the car wore "650" as its #, mag fronts, black steel rears. My point is that at that time Chrysler would ship bodies & parts to its contracted racers; that's what Cecil got to facilitate the car's later conversion. I would think that the "block of wood & a hammer" is a bit of understatement; it would appear to reference the rear axle location, which of course would also require centering/locating pins & holes and shortening the driveshaft. I've thought Chrysler did the 2% mods because they were pretty deliberate about only building 4 2% hardtops, using the '64 2% parts on those specific 4 '65s. I'll check with Cecil on that, as it's certainly possible that they just shipped the stuff to Melrose. That would be consistent with the logic of their later shipment for the 10/15 inch deal. I can post a clarification if anyone's interested.
[Re: 64Post]
#595385
01/28/10 01:08 AM
01/28/10 01:08 AM
LO23M8B
I have a theory I'm working on. I'd be curious as to what that was.... I wonder why Chrysler (Dodge/Plymouth) would release so many cars right before th 65' season. I mean they could have waited a month or so and made them all A-990 cars. What is with that? Were the cars late replacements for Max wedge cars that were ordered? Why would Chrysler make a similar number of each Dodge and Plymouth lightweights at 55 each and all steel cars at 35 each. Seems like someone thought about it enough to order even amounts of production. And for what purpose in the numbers? If they were just replacements for max-wedge orders, chances are they would be an odd number for each? What gives?
[Re: mr_340]
#595387
01/28/10 01:26 AM
01/28/10 01:26 AM
LO23M8B
My dads car,Aluminum nose hemi hardtop. IBM card has limited info. No dealer designation? An exception to the rule?
![](http://i144.photobucket.com/albums/r178/prochargedhemi/64plymouth5.jpg)
Kind of strange to see that car with single headlights and the MW scoop. Did it come like that from the factory? Maybe they ran out of the Hemi scoops and put the MW scoop/hood on instead.
Also it is not a post car. Single headlights, should be an aluminum front end post car. Not a hardtop with the Max-wedge scoop. Can you post the IBM card?
