Re: Carrier bearings - how to remove? [Re: aarcuda] #593984
01/26/10 02:34 PM
01/26/10 02:34 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
i think if you were to be grabbing the cage with that puller, you'd detroy the bearing by twisting the cage in to a pretzel.
you need to get the fingers of the puller onto the inner race or else
Exactly!
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Carrier bearings - how to remove? [Re: aarcuda] #593985
01/26/10 05:40 PM
01/26/10 05:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In an ideal world you're correct but pulling on the cage will most often remove the bearing without any damage to the cage.
Re: Carrier bearings - how to remove? [Re: John_Kunkel] #593986
01/26/10 06:28 PM
01/26/10 06:28 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
no, maybe not an ideal world. but it does seem to be the case in my world. every time i go and fix something, there are unintended casualties
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Carrier bearings - how to remove? [Re: aarcuda] #593987
01/26/10 06:37 PM
01/26/10 06:37 PM
So Cal
So Cal
Since the op has a cage and rollers missing this is another alternative if he can get a hold of the correct tools.
Have the bearing tool clamped down on the race lip where the rollers used to ride up against.
I think you can also buy this tool at harbor freight, just don't expect to do production work with it.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=3979
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93980
Re: Carrier bearings - how to remove? [Re: HealthServices] #593988
01/26/10 07:16 PM
01/26/10 07:16 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Make sure you use a good grade of high pressure grease on the puller threads or you could gall the threads and ruin the puller.
Been there, done that.
Re: Carrier bearings - how to remove? [Re: Snoopy] #593989
01/26/10 10:34 PM
01/26/10 10:34 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
yup, i toasted a HF puller using it the first time. no lube or anti seize
Re: Carrier bearings - how to remove? [Re: aarcuda] #593990
01/26/10 11:53 PM
01/26/10 11:53 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I use anti-seize on the puller threads.
