Page 2 of 4 1 2 3 4
Re: 69 383 HP some w holley carb some carter AVS why? [Re: Promopar] #593789
08/28/10 01:53 PM
08/28/10 01:53 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
The year makes all the difference in the world!
1968 383 4bbl 330hp AVS
1968 383HP 4bbl 335hp AVS
1969 383 4bbl 330hp Holley
1969 383HP 4bbl 335hp AVS
1970 383 4bbl 330hp AVS
1970 383HP 4bbl 335hp Holley
NO 383HP (335hp) c-bodies!!
I was told that the 69' road runner auto a/c 330hp used the Carter 4638.
Is this wrong?
Im using the 4638 on my 69 WP27H, 383/auto/AC
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 474218] #593790
08/28/10 02:01 PM
08/28/10 02:01 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
It appears 1969 is not as simple as my original post.
The 383 carb listing from the 1969 Chrysler Parts Catalog (Jan. '71 version).
Not 100% gospel - a duplicate part number listed for 2 different carbs.
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593791
08/28/10 02:08 PM
08/28/10 02:08 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 Monaco 383 4bbl auto (non-A/C) broadcast sheet - HOLLEY carb. Turquoise ENGINE August '68 SPD
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593792
08/28/10 02:22 PM
08/28/10 02:22 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 Charger 383 4bbl auto with A/C - HOLLEY carb. Turquoise ENGINE October '68 SPD
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593793
08/28/10 02:36 PM
08/28/10 02:36 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 Dart GTS 383 auto (non-A/C) - Carter AVS carb. Orange ENGINE April '69 SPD
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593794
08/28/10 02:48 PM
08/28/10 02:48 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 Road Runner 383 4bbl auto with A/C - HOLLEY carb. Turquoise ENGINE March '69 SPD
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593795
08/28/10 03:50 PM
08/28/10 03:50 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 Charger 383 4bbl 4-speed (non-A/C) - Carter AVS carb. Orange ENGINE July '69 SPD
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593796
08/28/10 03:58 PM
08/28/10 03:58 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 Super Bee 383 4bbl with A/C - HOLLEY carb. Turquoise ENGINE November '68 SPD
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593797
08/28/10 04:06 PM
08/28/10 04:06 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 Road Runner 383 4-spd (non-A/C) - Cater AVS carb. Orange ENGINE January '69 SPD
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593798
08/28/10 04:19 PM
08/28/10 04:19 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 Super Bee 383 auto (non-A/C) - Carter AVS carb. Orange ENGINE October '68 SPD
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593799
08/28/10 04:24 PM
08/28/10 04:24 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 Road Runner 383 auto (non-A/C) - Carter AVS carb. Orange ENGINE December '68 SPD
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593800
08/28/10 04:40 PM
08/28/10 04:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 Charger 383 4bbl auto with A/C - Carter AVS carb. Turquoise ENGINE
Here's a "problem child" - "Spring Special" Charger with A/C and a CARTER carb'd TURQUOISE engine.
How? What? Why?
Was this a running change (spring '69) away from Holley on the non-performance applications.
GG's "white book" lists the 4616S used without A/C & the 4638S used with A/C.
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593801
08/28/10 04:59 PM
08/28/10 04:59 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 Barracuda 383 4bbl 4-speed (non-A/C) - Carter AVS carb. Orange ENGINEAugust '68 SPD
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593802
08/28/10 05:40 PM
08/28/10 05:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
That's all the proof I can come up with right now. Who can add any sheets from April '69 & later?
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593803
12/06/11 02:53 AM
12/06/11 02:53 AM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
I am kicking this one back into the light for a couple reasons... to show an interesting buildsheet remnant for a '69 383, 4 speed car with A/C and to try and find out what carb I should be running on my car.
Have a look. The carb number is damaged a bit but by simple deduction of what is left, the number could either be a "3" or a "2". I am guessing '38' for the carb number.
I have a '69 383 roadrunner with 4 speed and A/C. I am not entirely sure after reading this thread and looking at this build sheet WHAT carb I should be running. I have heard 4711S, I have read 4615S and now I am seeing (possibly) this third choice - a holley 4440A.
I don't know what car this build sheet came out of but there is enough info on it to determine it was a '69 330 horse 383 (897 code), 4 speed (603 code) with H51. Most likely a B-body based on the trans number.
In another thread - more recent - I have been told an AVS 4711S is the correct carb for my application. Now I don't know what to think.
Any ideas?
Re: 69 383 H code some w holley carb some carter AVS why? [Re: ph23vo] #593804
12/06/11 04:43 AM
12/06/11 04:43 AM
I have never seen a stock 1969 Mopar with a 383 four barrel that had a Holley on it from the factory I have seen low performance(350 HP) 440 with them in C bodys. I use to have had some of those carbs I have worked on a lot of stock 1969 383 Hi Po Dodge and Plymouth cars back in the day, never saw a Holley on a 383 HP until 1970 I have learned to Never say NEVER on Mopars
Re: 69 383 H code some w holley carb some carter AVS why? [Re: Cab_Burge] #593805
12/06/11 05:53 AM
12/06/11 05:53 AM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
I agree with you. In looking at this sheet further, that first number does not appear to be a 3 (or a 2)...the shape of the contour doesn't match either of those numbers... its got to be a 9 equating to a 4711S.
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 70mopes] #593806
12/06/11 09:48 AM
12/06/11 09:48 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
I have a '69 383 roadrunner with 4 speed and A/C. I am not entirely sure after reading this thread and looking at this build sheet WHAT carb I should be running. I have heard 4711S, I have read 4615S and now I am seeing (possibly) this third choice - a holley 4440A. The 45 choke tells us it's an AVS. 56 indicates a Holley
I don't know what car this build sheet came out of but there is enough info on it to determine it was a '69 330 horse 383 (897 code), 4 speed (603 code) with H51. Most likely a B-body based on the trans number. the 897 assembly tells us it's from a B body
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 69 383 H code some w holley carb some carter AVS why? [Re: ph23vo] #593807
12/06/11 10:39 AM
12/06/11 10:39 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that seems to be the case. My old 70 383 S/E 4 speed charger had a little holley on it. Not sure if it was 4 speed vs auto or not. Maybe A/C vs non-A/C?
Coming soon!!!!
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 69CoronetRT] #593808
12/06/11 10:40 AM
12/06/11 10:40 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
back in 78 I bought a 68 R/T Charger 4 speed Dana.. It had a Holley and that car was as stock as stock could be. A self proclaimed Charger expert said ti wasnt stock.. In 81 I bought my 71 RR383 air grabber car. It had a factory Holley on it. The 67 440 New Yorker that my dad has was Holley equiped..
I am truckless..
Page 2 of 4 1 2 3 4
