Re: 69 383 HP some w holley carb some carter AVS why?
[Re: 6bblgt]
#593800
08/28/10 04:40 PM
08/28/10 04:40 PM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
1969 Charger 383 4bbl auto with A/C ![](/ubbthreads/images/graemlins/penguin-015.gif) - Carter AVS carb. Turquoise ENGINE Here's a ![](/ubbthreads/images/graemlins/confused.gif) "problem child" - "Spring Special" Charger with A/C and a CARTER carb'd TURQUOISE engine. How? What? Why?Was this a running change (spring '69) away from Holley on the non-performance applications. GG's "white book" lists the 4616S used without A/C & the 4638S used with A/C.
[Re: 6bblgt]
#593803
12/06/11 02:53 AM
12/06/11 02:53 AM
Posts: 1,228 Maple Valley, WA
70mopes
Maple Valley, WA
I am kicking this one back into the light for a couple reasons... to show an interesting buildsheet remnant for a '69 383, 4 speed car with A/C and to try and find out what carb I should be running on my car.
Have a look. The carb number is damaged a bit but by simple deduction of what is left, the number could either be a "3" or a "2". I am guessing '38' for the carb number.
I have a '69 383 roadrunner with 4 speed and A/C. I am not entirely sure after reading this thread and looking at this build sheet WHAT carb I should be running. I have heard 4711S, I have read 4615S and now I am seeing (possibly) this third choice - a holley 4440A.
I don't know what car this build sheet came out of but there is enough info on it to determine it was a '69 330 horse 383 (897 code), 4 speed (603 code) with H51. Most likely a B-body based on the trans number.
In another thread - more recent - I have been told an AVS 4711S is the correct carb for my application. Now I don't know what to think.
Any ideas?
[Re: 70mopes]
#593806
12/06/11 09:48 AM
12/06/11 09:48 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
I have a '69 383 roadrunner with 4 speed and A/C. I am not entirely sure after reading this thread and looking at this build sheet WHAT carb I should be running. I have heard 4711S, I have read 4615S and now I am seeing (possibly) this third choice - a holley 4440A. The 45 choke tells us it's an AVS. 56 indicates a Holley
I don't know what car this build sheet came out of but there is enough info on it to determine it was a '69 330 horse 383 (897 code), 4 speed (603 code) with H51. Most likely a B-body based on the trans number. the 897 assembly tells us it's from a B body
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#593808
12/06/11 10:40 AM
12/06/11 10:40 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
back in 78 I bought a 68 R/T Charger 4 speed Dana.. It had a Holley and that car was as stock as stock could be. A self proclaimed Charger expert said ti wasnt stock.. In 81 I bought my 71 RR383 air grabber car. It had a factory Holley on it. The 67 440 New Yorker that my dad has was Holley equiped..
I am truckless..
