I believe Goodyear still makes hoses for this application. First of all, are you using the cast iron waterpump with the outlet on the drivers side? Do you have factory AC. If so here are the part numbers Upper with AC is 60661, Upper without AC is 60666, Lower is 60662. Find a parts store that handles Goodyear products and give them these numbers, They most likely will not be listed on their sources. They will have to order them. Autozone around handles Goodyear. The bypass hose is 63642 if you are still using the smaller nipple in the intake manifold.. These hoses fit very nicely and I'm sure you will like them. PM me with what you find out.
