Re: Rebuilt 340
[Re: RapidRobert]
#592635
01/24/10 10:33 PM
01/24/10 10:33 PM
70duster340
There was a friend of his there who advised that he worked in the oil industry for his career. He advised a straight weight oil (30W), with a good zinc additive. It did seem to run well when I was there, but he did have some difficulty getting it to idle. He made some adjustments to the carb, and it settled right down and idled well. Now you have me concerned that the oil should have been much darker?
Re: Rebuilt 340
[Re: RapidRobert]
#592637
01/24/10 10:53 PM
01/24/10 10:53 PM
70duster340
Well, I can only hope that my cam also survived. He had several other engines there that he was about to work on, but all were GM engines. He builds racing engines for his sons and friends, so I am hoping that he used the same degree of detail on my engine that he uses for them. I guess that only time will tell.
I can say that, while it was on the run stand, it never shook at all, but idled and ran very smoothly. I'm sure that part of this was the fact that the run stand and the mounts were all metal, but even so, if it were not running well, the stand still would have shaken at least a bit. It was also on casters so he could move it around. It was very steady during the run, which did last about 10 minutes. He assured me that he had already performed the cam break-in run before I was present for the other run.
Re: Rebuilt 340
[Re: RapidRobert]
#592639
01/25/10 11:00 AM
01/25/10 11:00 AM
70duster340
I hope that your concerns (and now mine) are unfounded, but all I can go on is his word on this. About the filter. Since I am going to hook up the dual remote filter when the engine is reinstalled, do I need to install a filter? Should I just use one of the 2 filters I have already purchased to use on the dual remote filters? I apologize, but I just want to do this correctly, since I have a lot of $$$ tied up in this.
Re: Rebuilt 340
[Re: 70duster340]
#592642
01/26/10 09:53 PM
01/26/10 09:53 PM
RapidRobert
You have the 90 deg adapter plate on there now as he used that during break it in? When up/running you are going to remove it & use the concave chrome iirc adapter that has 2 fittings that run 2 hoses out to your (dual fitting) remote setup? Is that correct? I'd take a small plastic grocery bag and tie it over where the filter goes on the 90 deg adapter to cap it. you could screw on one of the filters lightly to cap it also. Holler back.
Re: Rebuilt 340
[Re: 70duster340]
#592646
01/27/10 10:37 PM
01/27/10 10:37 PM
RapidRobert
Dont know if you can still get em new but I'd put an ad in the SB parts wanted as it would be a fairly common item. Get the felpro round perimeter gasket(dont kknow the part #) as it is thicker & seals better.
