Re: SB into a Colt
[Re: 79turbocolt]
#590023
01/23/10 10:34 PM
01/23/10 10:34 PM
Posts: 650 Kansas
racincuda
Kansas
Looks like LOADS of fun Would love to do a V8 version myself but for now I will just ![](/ubbthreads/images/graemlins/hammer.gif) on my ol Cuda
Re: SB into a Colt
[Re: colt340]
#590025
01/24/10 12:47 AM
01/24/10 12:47 AM
Posts: 699 Manassas, VA USA
Scamp451
Manassas, VA USA
Motor is held in by a plate on each side where the motor mounts bolted on to the block.
Al, I think I have some pics that you sent me a while back when I was playing with the Arrow chassis I had.
I will have to check my old PC to see if I can find some pics of the 440 shoved between it's limbs.
Re: SB into a Colt
[Re: 79turbocolt]
#590026
01/24/10 03:02 PM
01/24/10 03:02 PM
Posts: 3,053 Bowling Green, KY
cudaboy
Bowling Green, KY
Yeah it should be, 350 or so hp with an 8 valve head, in a car that weighs 2300 pounds at the most when its done, I dont see the need for a small block.
now that's a 4cyl i could live with in a Colt. How much modification was necessary to get it to fit? How did you adapt a 904? I'll take all the details you want to post.
thanks
Dennis
Re: SB into a Colt
[Re: cudaboy]
#590029
01/24/10 03:55 PM
01/24/10 03:55 PM
Posts: 10 Colorado Springs Colorado
79turbocolt
thanks
Made a different cross member mainly to get the steering in front(add a rack) dakota rwd application oil pan, fabbed up motor mounts, The adapter is a hard to find one to adapt to a sb 904 bellhousing, the easier engine to do is the cloud car 2.4 as far as the adapter goes, ththey are readily available.
Dennis
