Re: Looking for photos and info on V7W pinstripe [Re: WannaRunner] #588464
01/21/10 04:35 PM
01/21/10 04:35 PM
Olympia WA
rocketresto Offline
rocketresto  Offline
Olympia WA
WannaRunner, that's an unusual color combo but I like it alot. Is that original paint on your car?
Mike
Re: Looking for photos and info on V7W pinstripe [Re: rocketresto] #588465
01/21/10 07:15 PM
01/21/10 07:15 PM
Fitchbug, Mass.
WannaRunner Offline
WannaRunner  Offline
Fitchbug, Mass.
Well, they say the odd colored RR's survived the best,lol. no teenager wants a "gold" RR. My RR is optioned T3 honey bronze all around, most were T5 or T7 when someone wanted the bronze paint. My fender tag listas a 9/68 build date, if ya look at my hood (pic below) you can see the effects of 41.5 years of opening the hood, paints a little thread bare, lol. There are a few patches that have been touched up. (very small) it is going for a repaint when I get the funds, so for now I left the hood alone to add a little "character" to the car. aside from the obvious high wear items that have been replaced its mostly a orginal plain jane RR......
Re: Looking for photos and info on V7W pinstripe [Re: 70mopes] #588466
01/21/10 07:18 PM
01/21/10 07:18 PM
Fitchbug, Mass.
WannaRunner Offline
WannaRunner  Offline
Fitchbug, Mass.
Thanks for posting those pix WannaRunner
Here is a shot from the '69 brochure.
Your Welcome!
Re: Looking for photos and info on V7W pinstripe [Re: WannaRunner] #588467
01/22/10 10:28 AM
01/22/10 10:28 AM
Elizabethtown, KY
6T9Hemi Offline
6T9Hemi  Offline
Elizabethtown, KY
Exactly how wide is the stripe WannaRunner?
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Looking for photos and info on V7W pinstripe [Re: 6T9Hemi] #588468
01/22/10 05:27 PM
01/22/10 05:27 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
From blowing up the scaled picture posted earlier, it looks like 3/8ths from top edge of quarter to centerline of pinstripe. Width of pinstripe looks to be 1/8th. WannaRunner is that about right?
Re: Looking for photos and info on V7W pinstripe [Re: 70mopes] #588469
01/22/10 07:00 PM
01/22/10 07:00 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
There are two stripes for '69 that I know of; a thin single pinstripe (black and white for sure and maybe red????) a wide(r) double stripe and one rumored thin double stripe but have only seen this last one a couple of times. The single thin "pinstripe" was the only stripe available on the '68 road runner and attached is the one on my '68 rr.
Re: Looking for photos and info on V7W pinstripe [Re: A12] #588470
01/22/10 07:07 PM
01/22/10 07:07 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
another:
Re: Looking for photos and info on V7W pinstripe [Re: A12] #588471
01/22/10 07:18 PM
01/22/10 07:18 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
this is the wider double '69
Re: Looking for photos and info on V7W pinstripe [Re: A12] #588472
01/22/10 07:27 PM
01/22/10 07:27 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This is from the 1969 road runner option list so I would think the double stripe would be the "sport stripe" and the single the "accent stripe".
MikeR
Re: Looking for photos and info on V7W pinstripe [Re: A12] #588473
01/22/10 10:31 PM
01/22/10 10:31 PM
Fitchbug, Mass.
WannaRunner Offline
WannaRunner  Offline
Fitchbug, Mass.
Sorry for the delay in responding guys, I have a reference chart some where and I was trying to find it, I had no luck. I don't want to pass along bad info so I'll pass along what I remember from looking into this about 3 years ago. A12, you are correct in that the single stripe is a "accent" stripe. My reference chart has the "correct" thickness of the stripe and correct placement below the body line(crease) but again I can't find it. I want to say the stripe thickness was supposed to be 1/8" to 3/16" and the stripe was supposed to be 3/8" off the bottom of the body line. Now I use the word "supposed" for a reason, as I noted in my earlier posts the thin stripes were applied using 2 wheels placed on both sides of the car, I have a picture of them on the reference chart that I can't find, maybe someone else on moparts has one? the wheels look like the wheels you use to check distance with. From what I remember, these paint wheels weren't super accurate, if the tension wasn't set right the thickness of the stripe would vary and it did not maintain a perfect distance from the body line. As I noted in my earlier posts the stripe on my RR does not look bad at all, but if you measure it, the distance from the body line to stripe varies from 1/4" to 1/2" you can also see where the wheels just sorta "fall off" after running down the side of the car. I'll keep looking for my chart, it will explain it better and has all the demensions. If you see a perfect, as in a consistent "painted" pinstripe on a RR it wasn't put there by Ma Mopar, lol.....
Re: Looking for photos and info on V7W pinstripe [Re: A12] #588474
01/23/10 02:45 PM
01/23/10 02:45 PM
Olympia WA
rocketresto Offline
rocketresto  Offline
Olympia WA
That's the V6W tape stripe. B.T.W. I think the A12 pictured is the one in my shop currently under going a rotisery restoration.
Mike
Re: Looking for photos and info on V7W pinstripe *DELETED* [Re: rocketresto] #588475
01/23/10 04:04 PM
01/23/10 04:04 PM
SE Pa.
LimeliteAero Offline
SE Pa.
Post deleted by LimeliteAero
Re: Looking for photos and info on V7W pinstripe [Re: LimeliteAero] #588476
01/24/10 05:42 PM
01/24/10 05:42 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
speaking of stripes
heres some V6 sport stripes
red
5757297-19af_3.jpe (102 downloads)
Re: Looking for photos and info on V7W pinstripe [Re: Day2Runner] #588477
01/24/10 05:49 PM
01/24/10 05:49 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
white
my b5 rr has the V6W stripe
