Re: Looking for photos and info on V7W pinstripe
[Re: 70mopes]
#588466
01/21/10 07:18 PM
01/21/10 07:18 PM
Posts: 299 Fitchbug, Mass.
WannaRunner
Fitchbug, Mass.
Thanks for posting those pix WannaRunner
Here is a shot from the '69 brochure.
Your Welcome!
[Re: WannaRunner]
#588467
01/22/10 10:28 AM
01/22/10 10:28 AM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
Exactly how wide is the stripe WannaRunner?
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
[Re: A12]
#588470
01/22/10 07:07 PM
01/22/10 07:07 PM
Posts: 21,555 N.E. OHIO, USA
A12
N.E. OHIO, USA
[Re: A12]
#588473
01/22/10 10:31 PM
01/22/10 10:31 PM
WannaRunner
Fitchbug, Mass.
Sorry for the delay in responding guys, I have a reference chart some where and I was trying to find it, I had no luck. I don't want to pass along bad info so I'll pass along what I remember from looking into this about 3 years ago. A12, you are correct in that the single stripe is a "accent" stripe. My reference chart has the "correct" thickness of the stripe and correct placement below the body line(crease) but again I can't find it. I want to say the stripe thickness was supposed to be 1/8" to 3/16" and the stripe was supposed to be 3/8" off the bottom of the body line. Now I use the word "supposed" for a reason, as I noted in my earlier posts the thin stripes were applied using 2 wheels placed on both sides of the car, I have a picture of them on the reference chart that I can't find, maybe someone else on moparts has one? the wheels look like the wheels you use to check distance with. From what I remember, these paint wheels weren't super accurate, if the tension wasn't set right the thickness of the stripe would vary and it did not maintain a perfect distance from the body line. As I noted in my earlier posts the stripe on my RR does not look bad at all, but if you measure it, the distance from the body line to stripe varies from 1/4" to 1/2" you can also see where the wheels just sorta "fall off" after running down the side of the car. I'll keep looking for my chart, it will explain it better and has all the demensions. If you see a perfect, as in a consistent "painted" pinstripe on a RR it wasn't put there by Ma Mopar, lol.....
[Re: A12]
#588474
01/23/10 02:45 PM
01/23/10 02:45 PM
Posts: 335 Olympia WA
rocketresto
Olympia WA
this is the wider double '69
That's the V6W tape stripe. B.T.W. I think the A12 pictured is the one in my shop currently under going a rotisery restoration. Mike
