98 Dodge W350 lights flashing Help Please #587885
01/19/10 07:34 PM
01/19/10 07:34 PM
Ridgeland, WI, 54763
Curt57 Offline OP
Curt57  Offline OP
I've got a 98 Dodge that after its run for a while.The lights flash intermitantly. There is no pattern. I have traced it past the light switch. So it's not the switch. It does it on both high and low beam. It also blows the marker light fuse now and then. Please help. It's driving me nuts.
Re: 98 Dodge W350 lights flashing Help Please [Re: Curt57] #587886
01/19/10 08:14 PM
01/19/10 08:14 PM
vashon island washington
hunterstroble Offline
I've never worked on one of theese, but it sounds like you got a short to power, check near the battery, I've seen battery acid eat harnesses.
1969 Dodge dart 500 stroker 1973 Dodge Challenger 440
Re: 98 Dodge W350 lights flashing Help Please [Re: Curt57] #587887
01/19/10 08:55 PM
01/19/10 08:55 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
check the bulkhead connector where the headlight circuit passes through the firewall. Fairly common for the connection to corrode green and rot off.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
