Rear Axle 7 1/4 sealed bearing? #586285
01/18/10 10:37 AM
01/18/10 10:37 AM
Long Island, New York
Tony H Offline OP
Tony H  Offline OP
Just pulled the raer drums ( 9") to eyeball teh shoes. Drivers side was all wet. Didn't smell like Gear oil and didn't smell like Brake Fluid.
It smells like Bearing Grease, So I assume the Bearing doesn't get lubed by the Gear oil in the Diff.
Looking at replacement Bearing and seal it appears that they have a Sealed bearing that presses on the axle. And the Seal is about $20 Seems very expensive for a seal. Slide hammer to the axle to get it out is no biggy. but what's the deal with the seal. Does it seal into the axle housing or this Flange bracket? Why so expensive. The callout for the 8 3/4 axle seal is $5 much more realistic. They also had a different callout for 10" and 9" brakes. confusing.
My experience with Axle rebuilds have always been with the 'C' clip at the Diff type wher ethe Bearing and seal get pressed into the axle housing and the axle just slides in..
'75 CJ5 with all glass body and a 350 Chevy SB
'85 Chevy Stepside (the wife's)
'89 Volvo
All 100% maintained by me.
'70 valiant DD for my son
'74 Dart Swinger..Latest endeavor
http://home.lyse.net/brox/TonyPage4.html
Re: Rear Axle 7 1/4 sealed bearing? [Re: Tony H] #586286
01/18/10 10:40 AM
01/18/10 10:40 AM
vashon island washington
hunterstroble Offline
sounds like a good excuse to throw away that 7.25 abd atleast get an 8.25
1969 Dodge dart 500 stroker 1973 Dodge Challenger 440
Re: Rear Axle 7 1/4 sealed bearing? [Re: Tony H] #586287
01/18/10 11:21 AM
01/18/10 11:21 AM
Hi Tony. I'd pull the old inner seal out & drive in a new one & leave the flange/seal on the axle alone, taking the same care on driving the inner seal in as you do on an 8&3/4 so as not to damage it. (packing the rear spring side w grease/using as large a dia of flat face driver as will fit in there/starting it in w several easy hits to get it started square/then driving it in w your biggest hammer w as few strokes as possible keeping it square to minimize any chances of distorting it).
Re: Rear Axle 7 1/4 sealed bearing? [Re: RapidRobert] #586288
01/18/10 12:40 PM
01/18/10 12:40 PM
Tony H Offline OP
Tony H  Offline OP
This '70 Valiant is my kids daily driver. The swap out for the 8 3/4 for this Slant six driver is not in the cards for this vehicle. Running and reliable is te name of this game.
You think the gear oil is bleeding thru the outer bearing and outer seal to get on the brakes? I would smell that distinct gear oil smell, no?
I've done inner seals on my Jeep axle. a long rod from Drivers side to smack in the passenger side seal and vise/verse.
'89 Volvo
Re: Rear Axle 7 1/4 sealed bearing? [Re: Tony H] #586289
01/18/10 04:24 PM
01/18/10 04:24 PM
It's been such a long time since I've been in a 7&1/4 that I didn't even remember about their sealed bearing. When you said it is all wet it sure sounds like classic leaky cyl or gear lube from the center diff. A sealed bearing is not going to have very much lube in it.
Re: Rear Axle 7 1/4 sealed bearing? [Re: RapidRobert] #586290
01/18/10 05:48 PM
01/18/10 05:48 PM
md
mopars4ever Offline
mopars4ever  Offline
md
sorry wrong info for a early 7 1/4
Re: Rear Axle 7 1/4 sealed bearing? [Re: mopars4ever] #586291
01/18/10 06:01 PM
01/18/10 06:01 PM
md
mopars4ever Offline
mopars4ever  Offline
md
sorry wrong info for early 7 1/4
Re: Rear Axle 7 1/4 sealed bearing? [Re: mopars4ever] #586292
01/18/10 07:11 PM
01/18/10 07:11 PM
Tony H Offline OP
Tony H  Offline OP
No inner axle seal on a 7 1/4 or 8 1/4. Bearing is lubed by the rear axle grease. Are you sure they gave you the correct bearing. My 8 1/4 has just a roller type bearing not sealed. Here is some good info to read.
http://www.dippy.org/svcman/sm03a.html#AXLESHAFTASSEMBLE
Guys, This is what is getting me nuts. The Bearing and seals that you just showed me, along with the 'C' clip that holds the axle from the Diff is what I am used to seeing and what I have worked on. However, I am getting another story from a genuine '68 MOTORS repair manual. They show specifically a 7 1/4 axle and it shows this order of assembly, Seal (that looks like it seals about 6" into the axle Housing), then a Collar on the axle , a bearing on the axle and a Retainer that bolts up to the housing.
Basically it looks like you slide the retainer over the axle, Press on a Bearing then press on this retainer slide the axle into the housing and the Retainer bolts to the Housing and that's what keeps the axle in. There is No 'C' clips in the Diff. Looks like you do not have to pull off the Diff cover at all.
Heck if the seal is where it describes in this Book, and I don't have to pull the bearing off the axle.. that's great. But I don't know who is right at this point
'89 Volvo
Re: Rear Axle 7 1/4 sealed bearing? [Re: Tony H] #586293
01/18/10 07:40 PM
01/18/10 07:40 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You may be right, I'll have to dig up some nos ones out in the garage. IIRC, they are in boxes with a locking collar only. Just a sealed bearing and a lock collar. so if the axle retainer does not do the sealing, there must be a seal pressed in housing.
Re: Rear Axle 7 1/4 sealed bearing? [Re: buildanother] #586294
01/18/10 09:48 PM
01/18/10 09:48 PM
md
mopars4ever Offline
mopars4ever  Offline
md
You are correct the 68 7 1/4 axle is different. There is a inner seal and bearing with collar. I looked at a view in a 68 parts book. Sorry for the confusion. I didn`t know what year you were working with.
Re: Rear Axle 7 1/4 sealed bearing? [Re: mopars4ever] #586295
01/30/10 03:22 PM
01/30/10 03:22 PM
Tony H Offline OP
Tony H  Offline OP
I just pulled the axle out of the '68. Inner seal type. The one I need to seal is in a '70 Valiant. I am guessing buy the Plate on the end that it is the same setup.
Interesting: I think the seal was installed backwards in the '68. The Solid Face was facing into the axle while I was looking at the Hollow end. Also I measured 0.5" width on the one I pulled from the '68 axle yet a NAPA replacement shows a 0.33 wide. The ID and OD look like they should be OK
'89 Volvo
