5.2 magnum bypass a/c compressor #585705
01/17/10 05:30 PM
01/17/10 05:30 PM
WI
RestoRick Offline OP
WI
I have my a/c compressor removed on my 5.2L 99 Ram and one of those bolt-in pulleys to replace it.
The china bearings are starting to squeal.
On a previous thread someone mentioned using a shorter 6-rib belt, but no spec on length.
I also found mention on another site of using a
7-rib 90 5/8" length belt.
Can anyone confirm this length?
Thanks,
Rick
Re: 5.2 magnum bypass a/c compressor [Re: RestoRick] #585706
01/17/10 05:37 PM
01/17/10 05:37 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Check the dealer parts list. They made a dummy pulley that bolted in place of the ac comp for a no ac truck.Check from 92 up.
Leave the gun.......take the Cannoli's....Mike
Re: 5.2 magnum bypass a/c compressor [Re: mike s] #585707
01/17/10 05:49 PM
01/17/10 05:49 PM
WI
WI
I have a dummy pulley on it... I'd rather eliminate that altogether and just use a shorter belt if possible.
Re: 5.2 magnum bypass a/c compressor [Re: RestoRick] #585708
01/17/10 06:52 PM
01/17/10 06:52 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Sorry I missed that.I doubt the wrap will be correct without the dummy.We only ran ac or dummy.
Re: 5.2 magnum bypass a/c compressor [Re: RestoRick] #585709
01/17/10 07:35 PM
01/17/10 07:35 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
Rick,
Go over to the dakotart list and post your question, someone there will know the belt size. I run the 6 rib and would look for you but the truck is burried under covers and snow right now.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: 5.2 magnum bypass a/c compressor [Re: blk00rt] #585710
01/17/10 08:04 PM
01/17/10 08:04 PM
WI
WI
Thanks Rob!
Found it with their search engine.
K070896 90 1/8"
