Cool intake manifold for a 318? #58545
05/14/08 10:54 PM
05/14/08 10:54 PM
Upstate, NY
sixpack4spd Offline OP
Upstate, NY
I was planning on putting a 451 with a vintage looking weiand 3x2 intake on it in my 46 PU. Lately, I've been considering running a 318 in it. Are there any "vintage" looking intakes you can run on a 318? Anyone add "dummy" carbs to a stock 2bbl intake???
Re: Cool intake manifold for a 318? [Re: sixpack4spd] #58546
05/15/08 12:15 AM
05/15/08 12:15 AM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
Back in 76 when I had my 48 morris van, I ran a 318 with a 2bbl on it and I had a gutted out 471 blower case mounted over it and had 2 gutted out carter 4 bbl carbs mountend on top of the fake blower and had the air cleaners on them and had a hilborn scoop on the carbs. I had about $150.00 into the whole thing. I ran a belt gaurd on it so I didn't have torun a belt on it. it looked pretty real
I also thought about running a plate under a 2 bbl carb and mount 2 end carbs to make it look like a tripower Ron.....
Re: Cool intake manifold for a 318? [Re: sixpack4spd] #58547
05/15/08 11:57 AM
05/15/08 11:57 AM
E
earlymopar Offline
earlymopar  Offline
E
IMO, the best "vintage' look would be a poly-318 with either the factory 2-4 set-up or the aftermarket 3-2 manifold.
- EM
Re: Cool intake manifold for a 318? [Re: earlymopar] #58548
05/15/08 12:47 PM
05/15/08 12:47 PM
Upstate, NY
Upstate, NY
I've got a poly 318 in a parts car but it would need a rebuild. I have a 318/auto out of a 70 Challenger that runs good that I was thinking of using instead of the big block. I really didn't like to looks of the poly motor. I'll probably stick with the big block. I've already got the intake. Maybe I'll just use a mild 383 in it...
Re: Cool intake manifold for a 318? [Re: Mopar Ron] #58549
05/15/08 12:49 PM
05/15/08 12:49 PM
Upstate, NY
Upstate, NY
Hmmm, it would be easy to bolt some extra carbs to a plate.
Re: Cool intake manifold for a 318? [Re: sixpack4spd] #58550
05/15/08 02:54 PM
05/15/08 02:54 PM
dogdays Offline
dogdays  Offline
2-4s on a tunnel ram, shouldn't be that hard to find.
R.
keep in mind that any LA intake will bolt up....................................................................
Re: Cool intake manifold for a 318? [Re: sixpack4spd] #58551
05/17/08 10:22 PM
05/17/08 10:22 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
As a matter of fact...If you go to speedwaymotors.com they have an intake adapter that bolts to a stock 4bbl intake that allows you to run a couple of holley 94's. But really you could use this on any 4bbl intake..
Re: Cool intake manifold for a 318? [Re: sixpack4spd] #58552
05/20/08 02:14 PM
05/20/08 02:14 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
couldn't you just run a 340-6 manifold??? I know the ports are a different size but it seems you don't care much aboout performance so why not?
Re: Cool intake manifold for a 318? [Re: Mr.Yuck] #58553
05/20/08 05:42 PM
05/20/08 05:42 PM
Imlay City, MI
DTT Offline
super gas
DTT  Offline
super gas
Imlay City, MI
How many carbs do you want? Are you just after a "look" ?? Offy makes a 2 carb intake setup for 2 4's, AFB style carbs.... The part number is: Offenhauser 5615
1978 Pro Street D100 1936 Dodge truck (Hot rod) 1957 Plymouth Plaza 1962 Chrysler 300 1964 Dodge 440 1995 Jeep Grand Cherokee 1971 Big Block Demon (Dads)
Re: Cool intake manifold for a 318? [Re: Mr.Yuck] #58554
05/20/08 06:57 PM
05/20/08 06:57 PM
Mopar Ron Offline
Mopar Ron  Offline
I think that the issue is price a 340 6 pack setup can run close to or over $2,000. and just bolting a plate to the 2bbl to make it look like a tri power with the 2 end carbs costing just about nothing at a junkyard, and you keep the economy of the stock 2bbl Ron...
Re: Cool intake manifold for a 318? [Re: Mopar Ron] #58555
05/23/08 08:23 AM
05/23/08 08:23 AM
Truckville, the capital of NY
85_Ram_4speed Offline
Something im brewing up for my truck
Outcast Dodge guy.
Re: Cool intake manifold for a 318? [Re: 85_Ram_4speed] #58556
05/23/08 09:47 AM
05/23/08 09:47 AM
Cambridge Idaho
RUMBLON Offline
RUMBLON  Offline
Cambridge Idaho
not trying to hikack the thread but I am also interested but want drivability????
LAWFISH
Re: Cool intake manifold for a 318? [Re: Mopar Ron] #58557
05/27/08 02:49 PM
05/27/08 02:49 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Mopar Performance Dual Plane Six Pack Intake Manifolds
Intake Manifold, Dual Plane, Aluminum, Natural, Six Pack, Chrysler/ Dodge/ Plymouth, 318/ 340/ 360, Each.... $299.99
Re: Cool intake manifold for a 318? [Re: Mr.Yuck] #58558
05/27/08 04:02 PM
05/27/08 04:02 PM
dogdays Offline
dogdays  Offline
The sixpack manifold is the cheap part. By the time you get the carbs and linkage you have a lot more in it than $300!
I'd still go the tunnel ram with two small 4-barrels or 2-barrels. Also with a tunnel ram the older the better as they tended to have smaller runners.
R.
Re: Cool intake manifold for a 318? [Re: Mr.Yuck] #58559
05/27/08 08:12 PM
05/27/08 08:12 PM
Mopar Ron Offline
Mopar Ron  Offline
yes the intake is $300. but the carbs are around $1,000. (see below) and the air cleaner and linkage and gas line all add it up to close to $2,000.
I love the 6 pack setups but to do something different and cheap the plates under a 2bbl can be made to look cool Ron...
http://cgi.ebay.com/ebaymotors/HOLLEY-34...0240609403&
Re: Cool intake manifold for a 318? [Re: 85_Ram_4speed] #58560
05/27/08 11:03 PM
05/27/08 11:03 PM
Asheboro NC
mopowertim Offline
super gas
mopowertim  Offline
super gas
Asheboro NC
This is interesting.....
If you can't outrun it-Outlaw it! The King
Re: Cool intake manifold for a 318? [Re: mopowertim] #58561
05/28/08 10:52 AM
05/28/08 10:52 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that is coool but why not just use 2 small holleys? those FoMoCo carbs ar 500 cfm each. You could use 2 450 vacuum holleys and use off the sheft linkage.
Re: Cool intake manifold for a 318? [Re: Mr.Yuck] #58562
05/28/08 08:39 PM
05/28/08 08:39 PM
Indianapolis
Waveraider Offline
Happy Birthday Waveraider  Offline
Indianapolis
Why not buy a repro fiberglass air grabber air cleaner and make an adapter to fit the 2 bbl carb. Nobody will be able to see whats under it. Bad pic and not painted, but this should give you an idea.
Ron, are you still selling those?
