T5 Trans to Slant Six Engine Adapter Plate Source? #583484
01/15/10 05:01 PM
01/15/10 05:01 PM
Milwaukee, WI
In_The_Pink Offline OP
Milwaukee, WI
Does anybody make a T5 to Slant Six adapter plate? Ford, Chevy, Isuzu, Nissan, etc. pattern.
Re: T5 Trans to Slant Six Engine Adapter Plate Source? [Re: In_The_Pink] #583485
01/15/10 05:10 PM
01/15/10 05:10 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Castlemain Rod Shop in Oz probably do...
(That is who I got my Hemi-6/small block to T5 one from..)
Re: T5 Trans to Slant Six Engine Adapter Plate Source? [Re: OzHemi] #583486
01/15/10 05:49 PM
01/15/10 05:49 PM
Milwaukee, WI
Milwaukee, WI
Do you use a GM pattern (non-WC or WC?) T5 with that adapter?
Re: T5 Trans to Slant Six Engine Adapter Plate Source? [Re: In_The_Pink] #583487
01/15/10 05:55 PM
01/15/10 05:55 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
WC out of a '92 GT...
With thier setup though, it uses a bellhousing and a middle plate, so it can handle different input shaft lengths and transmissions. Same bellhousing will suit the T5 and the TKO for instance, just with the right thickness mid plate.
At least how they did make them...I bought mine years ago and the place changed hands since (but still makes all the same stuff I believe)
It had a mounting pad for a hydraulic slave cylinder too, which is what you'd have to use in a LHD car I suppose...I just used the clutch fork it came with, along with the factory linkage on the Charger.
Re: T5 Trans to Slant Six Engine Adapter Plate Source? [Re: OzHemi] #583488
01/15/10 05:56 PM
01/15/10 05:56 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Again, this is the Hemi/Small block one, not for a slant, but you get the idea at least..
Re: T5 Trans to Slant Six Engine Adapter Plate Source? [Re: OzHemi] #583489
01/15/10 06:06 PM
01/15/10 06:06 PM
Milwaukee, WI
Milwaukee, WI
Thanks. Isn't the cluch fork on the wrong si- err, nevermind.
I found a bunch of info over at slantsix.org , too.
Re: T5 Trans to Slant Six Engine Adapter Plate Source? [Re: In_The_Pink] #583490
01/15/10 06:12 PM
01/15/10 06:12 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
No prob
Re: T5 Trans to Slant Six Engine Adapter Plate Source? [Re: OzHemi] #583491
01/15/10 06:13 PM
01/15/10 06:13 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Oh, and just for giggles...here it is in the car, and you can see that middle plate on the bellhousing too
Re: T5 Trans to Slant Six Engine Adapter Plate Source? [Re: In_The_Pink] #583492
01/15/10 09:58 PM
01/15/10 09:58 PM
AndyF Offline
AndyF  Offline
Call QuickTime. They can build a slant six bellhousing if they get enough interest.
