Plug Wire question
#581999
01/14/10 08:55 AM
01/14/10 08:55 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
I have been planning on getting a set of FireCore wires when I needed to change my wires. We start test and tune this weekend and here it is, a bad plugwire on 5 and 7. Aint that the way is usually goes? Question is, I have an MSD 6AL box. Someone told me yesterday that with that box, I'm wasting my money getting a good set of wires. All I need is a regular set of 7mm. Is that true? He said I would need better wires if I put in a bigger ign box like a 7al or something like that. Would a more expensive set of wires help ET or anything? I have to do something today with it to be ready to make some passes with it this weekend.
Thanks in advance Dub
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Plug Wire question
[Re: StandOnIt]
#582001
01/14/10 11:25 AM
01/14/10 11:25 AM
Posts: 7,506 Az
Crizila
Az
When it comes to ignition wires, you pretty much pay for what you get. Matching ignition components is ok, but I personnally like to go over kill on the wires ( 8MM, low impedance, jacketed, heat resistant boots, etc. ) as you don't want them to be the limiting factor in your ignition system. A little more $ up front, but you get to cross that worry off your list.
Fastest 300
[Re: Crizila]
#582002
01/14/10 12:35 PM
01/14/10 12:35 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
Spend the money once get them wires, their da bestes
[Re: B1KILLER]
#582003
01/14/10 12:53 PM
01/14/10 12:53 PM
StandOnIt
Baton Rouge, La.
Thats what I thought!! It made perfect sense to me but I have been know to be waaayyy off...lol FireCore order placed. Thanks Rick.
