ignition removal help needed #580682
01/12/10 08:38 PM
01/12/10 08:38 PM
mn
moparmaniac Offline OP
super street
super street
mn
Is there anyway to remove the ignition lock in the
steering column on a 74 roadrunner without the keys?
Re: ignition removal help needed [Re: moparmaniac] #580683
01/12/10 09:18 PM
01/12/10 09:18 PM
You have to pull the steering wheel & go inside to depress the mini pin to let the lock assy come out. No way from the outside otherwise it (ign in the column) wouldn't be much of an antitheft feature.
Re: ignition removal help needed [Re: RapidRobert] #580684
01/12/10 09:34 PM
01/12/10 09:34 PM
mn
super street
super street
mn
thanks for the reply. So I don't need the key to
get it out?
Re: ignition removal help needed [Re: moparmaniac] #580685
01/12/10 09:36 PM
01/12/10 09:36 PM
get it out?
correct EDIT it'd be (MUCH) easier to take off a door panel & take out a door lock cyl & have your locksmith rekey it rather than opening up the st col.
