Small block cam bearing: What do you like? #579524
01/11/10 01:19 PM
01/11/10 01:19 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Looking for cam bearings for my 340. What do you recommend? Thanks.
Re: Small block cam bearing: What do you like? [Re: ragtop] #579525
01/11/10 01:37 PM
01/11/10 01:37 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
I recomend that you don't use Lack's Automotive in Lynchburg VA to install them!
Re: Small block cam bearing: What do you like? [Re: 74RALLYE] #579526
01/11/10 03:34 PM
01/11/10 03:34 PM
Mooresville, NC
I
Intense RT Dan Offline
I
Mooresville, NC
Durabond. They don't just roll a flat piece of steel (the backing) and plate/coat it. It's one solid piece all the way around.
Re: Small block cam bearing: What do you like? [Re: ragtop] #579527
01/11/10 04:15 PM
01/11/10 04:15 PM
I've never had a problem w any brands & that is a pretty low stressed/trouble free area. the trick is to take care when installing them w the tool & the hot trick is to use an old cam w slots cut diagonally in the journals to open them up. With a bit of shopping you can get a set to your door for $20 or $25. I also drill/tap/plug the vertical crank to cam passages (5 of them) w set screws w 1/16" holes drilled in them to restrict the oil in any journal that does not also feed the rocker arms and 1/8" on those. Works fine & the journals/bearings look great & keeps more oil where it is needed.
