A-990 Hood scoop #579343
01/11/10 12:08 AM
01/11/10 12:08 AM
STL ,MO
Handygun Offline OP
Handygun  Offline OP
STL ,MO
Does anyone on here know if the 65 A-990 hoodscoop will cover a Indy 4150 style single plane intake on a Hemi w/aircleaner? the car is a 65 Coronet w/schumacher mnts, I'd like to pick up a scoop at Indy swap and it is one of the last things I need, car is a street/strip car hence the aircleaner, thanks Steve
Re: A-990 Hood scoop [Re: Handygun] #579344
01/11/10 12:36 AM
01/11/10 12:36 AM
fullmetaljacket Offline
The A990 might be a little tight, but the 65' AFX scoop will. It is a taller version of the A990. Now if you want one, don't go fiberglass, ask if Harms smith here will fab one using there A990 template. It might be expensive.
I made my own 65" AFX scoop out of aluminum and it can clear a skyscraper. It totally looks original.
Re: A-990 Hood scoop [Re: fullmetaljacket] #579345
01/11/10 12:46 AM
01/11/10 12:46 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks but sorry, I'm no longer offering those.
Re: A-990 Hood scoop [Re: Handygun] #579346
01/11/10 07:33 AM
01/11/10 07:33 AM
wappinger falls new york
Jimi_Vignogna Offline
i had a 1964 savoy with a hemi, barton single 4bbl intake,dominator, it fits under a stock a990 hood scoop, no carb mounted air cleaner, i had a pan seal to the hood and air cleaner was inside the front of the hood scoop.
Re: A-990 Hood scoop [Re: fullmetaljacket] #579347
01/11/10 08:33 AM
01/11/10 08:33 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Here is FULLMETALJACKET with his home hammered scoop
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: A-990 Hood scoop [Re: hemi-itis] #579348
01/11/10 01:15 PM
01/11/10 01:15 PM
Thanks hemi-itis.
This is the home made scoop I fabricated out of aluminum. It was a weeks time in the making because of different places where it was conceived by part.
I first started out by making the first break bends on the staircase banisters of my Mothers building., then hammering it out on a Brooklyn Navy Yard blacksmith table before bringing to my good friend at a welding shop to run the aluminum weld beads.
There was nothing like it out in the market at the time and after I mentioned to Kramer automotive specialties to make one for the coming outlaw Nostalgia trend with out no results, I made it myself.
The 1965 Factory altered wheel base AFX cars had these right out of box.
Re: A-990 Hood scoop [Re: fullmetaljacket] #579349
01/11/10 01:35 PM
01/11/10 01:35 PM
STL ,MO
Handygun Offline OP
Handygun  Offline OP
STL ,MO
Thanks for the ideas and pics, is the Barton intake shorter than the Indy? If I had a bond jig I'd like to make one out of composite,I need to put the motor and trans in and see where I am at height wise.
Re: A-990 Hood scoop [Re: Handygun] #579350
01/11/10 04:25 PM
01/11/10 04:25 PM
Do not ask Vignogna about INDY
Re: A-990 Hood scoop #579351
01/11/10 07:44 PM
01/11/10 07:44 PM
i just got a 65 dodge afx tall 5" hoodscoop made by sled city.
i'll be running a sheetmetal intake with 2 dominators. its going to be close imo.
