Any tricks/advice for removing a 67 GTX cluster?
#578672
01/10/10 03:30 PM
01/10/10 03:30 PM
Posts: 1,073 Newton, KS
70B5Cuda
Newton, KS
I have pulled 1 or 2 fox body clusters but never pulled a Mopar instrument cluster. Is there anything special I need to know? I assume I need to drop the column and pull the cluster out from the front. Will I be able to pull the cluster out 6-8 inches in order to remove the wires/speedo cable or do I do that first from underneath? Any other tips/pointers would be much appreciated. I just don't want to break something that is hard to replace/repair!
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
