500 stroker motor with 9.1 compression
#578485
01/10/10 01:07 PM
01/10/10 01:07 PM
Posts: 502 North Texas
1AARCUDA
North Texas
Would a 500 stroker motor with 9.1 compression benefit from 110 octane racing fuel or would I be wasting my money? Thanks!
1970 AAR CUDA
1970 Super Bee 383 Auto
1969 Super Bee 383 4Spd
1968 Satellite 500 Stroker
1986 Shelby GLHS
1970 Coronet 500 383 Auto
1996 Indy Pace Truck
1998 Dakota R/T 408 Stroker
Re: 500 stroker motor with 9.1 compression
[Re: 1AARCUDA]
#578487
01/11/10 04:56 AM
01/11/10 04:56 AM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
Is it suffering from detonation on pump gas?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 1AARCUDA]
#578488
01/11/10 07:42 AM
01/11/10 07:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Most likely it will hurt the performance unless it has a detonation issue(which I wouldnt think so)... JMO
[Re: 1AARCUDA]
#578489
01/11/10 10:44 AM
01/11/10 10:44 AM
1AARCUDA
North Texas
Have not fired it up yet, still waiting for parts to drop it in. What about a mixture of 93 octane and 110, maybe 2 gallons of 110 to 3 gallons of 93 in a 5 gallon jug?
1970 AAR CUDA
1986 Shelby GLHS
[Re: 1AARCUDA]
#578491
01/11/10 10:51 AM
01/11/10 10:51 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
It would if you threw on a big old turbo.....come on
[Re: Stanton]
#578492
01/11/10 11:04 AM
01/11/10 11:04 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Why not just 87 Octane regular ... it's a lousy 9:1 !!!
if it has aluminum heads it's the same as 7.5 to 1??
[Re: 1AARCUDA]
#578495
01/11/10 11:48 AM
01/11/10 11:48 AM
Posts: 1,263 Southwestern Ontario Canada
racealittle
If it is aluminum heads, 87 octane will do the job. Iron heads may need 91-93 until you get things sorted.
I run an aluminum head 9.3:1 440 on 87 and it's just fine.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: 1AARCUDA]
#578497
01/11/10 11:53 AM
01/11/10 11:53 AM
Dodgem
Ontario, Canada
Ok, I get it! Thanks for all the input. Happy Racing this coming year.
Well the 500 inches is not the requirement for octane but the final compression, coupled with cam specs and consideration for aluminum of iron heads.
A 9 to 1 motor with a 204/210 duration cam @ .050 may need some extra above 93 octane while a 275/284 @ .050 may not need any octane above 93 and may well run on less aluminum heads generally will need less octane than Iron.
[Re: 1AARCUDA]
#578499
01/11/10 12:03 PM
01/11/10 12:03 PM
1AARCUDA
North Texas
Cast Iron Stage V heads from Mopar Performance, I will have time to test and tune it in Feb, but looks like I would not need to spend $8.00 a gallon on 110
1970 AAR CUDA
1986 Shelby GLHS
[Re: 1AARCUDA]
#578501
01/11/10 12:08 PM
01/11/10 12:08 PM
1AARCUDA
North Texas
509 lift 248 duration @.50
1970 AAR CUDA
1986 Shelby GLHS
[Re: 1AARCUDA]
#578504
01/11/10 12:19 PM
01/11/10 12:19 PM
Quicktree
you probably need it. you do know the more octane you use the slower the burn rate right? I would start with regular 93 and work your way down.
