Page 2 of 3 1 2 3
Re: torque per cube? [Re: gregsdart] #578447
01/11/10 09:45 PM
01/11/10 09:45 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
I don't have much Dyno info on my 636ci since we only really ran it on there a few times to make sure everything was alright.
Made 913 lb-ft@ 5700rpm (dyno didnt pull it down any lower)
Made 801 lb-ft@ 7100rpm (didnt run it much higher then that on the dyno)
Those numbers come in right around 1.4 per cube
Re: torque per cube? [Re: MuscleMike] #578448
01/11/10 11:57 PM
01/11/10 11:57 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
622", 11.3:1, solid roller, 150psi cranking, 92 speedway premium, 1.4 per cid.
B1 heads are odd because they don't flow enough air relative to the port size (or CSA: cross section area) on a big inch combo the port is big enough to support the cid but the flow isn't there to support RPM so the engines tend to nose over early.
Mike @MM
Thats because they are a wedge and have limited valve size, right? Does the TS also lack flow for big inch motors?
Re: torque per cube? [Re: B1Fish540] #578449
01/12/10 01:08 AM
01/12/10 01:08 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
505", 13:1, 4.40" bore x 4.15 stroke,
Victor max wedge heads, 2.20"/1.81 valve, 355/284 cfm @ .700.
Solid roller 264/268 @ .050, .716 gross lift with 1.7 rockers
Super victor intake, 1050-8896 dominator, 2"/3.5" hooker super comp headers
Made 683 tq @ 5000, 768 hp @ 6500
If I did my math right, that's 1.35 ft lb per cube.
Made 689 and 776 with a 1.5" tapered spacer.
505" on the IMM dyno
Re: torque per cube? [Re: G_bob] #578450
01/12/10 01:44 AM
01/12/10 01:44 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I prefer to build a race engine for hp. If I want to build a tow truck I'll build for torque.
Re: torque per cube? [Re: dodgeboy11] #578451
01/12/10 10:02 AM
01/12/10 10:02 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Peek torque comes @ peek VE, the trick is to keep torque or VE as high as possible past 5250 for as long as possible, than you have a engine that will pull hard thru the power band, the longer the torque curve the higher the power band, the more rotational speed in RPM = more HP<disclaimer> this is the personal opinion of a small block engine guy with just a few years of experience, I could be totally wrong
Re: torque per cube? [Re: dodgeboy11] #578452
01/12/10 10:21 AM
01/12/10 10:21 AM
gregsdart Offline OP
I bet you would agree, that after you reach a very high hp level, you will be looking to enhance every step of the intended rpm range, right? Even if you sacrifice a peak hp spot, but spread out the torque, creating more average hp.
My best hp dyno sheet was not my best dyno pull, the one with the best average hp by 3 or 5 hp is my best overall combo.
One of my reasons for starting this post was to learn ways to move the torque peak up, as my combo goes fastest with the converter way over the present torque high point. Anything I can do to move that point higher will help, provided I don't loose too much in the process.
Post deleted by Defbob [Re: blownzoom440] #578453
01/12/10 10:26 AM
01/12/10 10:26 AM
Re: torque per cue? #578454
01/12/10 10:31 AM
01/12/10 10:31 AM
Hemifred, that is some serious power! I notice it makes 1.548 ft lbs per cube at 6,000 rpm. That is about as efficient a motor as I have seen listed so far!
Re: torque per cube? [Re: SportF] #578455
01/12/10 12:21 PM
01/12/10 12:21 PM
Kalispell Mt.
HotRodDave Online content
HotRodDave  Online Content
Kalispell Mt.
I am kinda curious why you would build for torque, assuming a race or even a pleasure motor. If you look at all the torque and horse power figures, torque on a decent motor is always within about 10% of HP. When you get like a nail head Buick that makes 350 HP and 450 pounds of torque, or a diesel that makes 300 hp and 600 ft pounds, well that's either a failure to rev or something else wrong.
I have heard guys talk and say it’s the torque that moves the car. Well, would you want 10,000 pounds of torque at 5 RPM? I don't think so, it wouldn't get you anywhere. I'd like to hear other opinions on this, but if it’s a race motor, you want power, don't you? That equates to RPM's and torque put together. Build for horse power and the torque will come.
Build for HP and the TQ will come through really low gear ratios and high stall TQ converters, things that make a car less fun to drive. This is why I build big high TQ motors for the street so I don't have to multiply it back into TQ
What ever ones end goal is (especially in a drag car is) to put as much TQ to the rear wheels as possible you can get it through high RPM power being multiplied back into TQ or just plain big TQ. It is just that big HP seels motors.
Re: torque per cube? [Re: HotRodDave] #578456
01/12/10 12:30 PM
01/12/10 12:30 PM
Kalispell Mt.
Kalispell Mt.
An example of what I was saying would be a 440 makeing 500 hp and 600Lbs TQ you could run it with 3.23 gears and have almost 2000 Lbs TQ at the rear axle(in direct gear for simplicity sake). On the other hand if you had a 302 ferd that made 500 hp you could go just as fast in an other wise equal car but you would only have 411 lbs tq (asumeing same tq per cube) in that motor so you would have to run a 4.86 gear to put the same amount of TQ to the rear axle in direct gear. It is TQ at the rear wheels that gets the car moveing.
Re: torque per cube? [Re: HotRodDave] #578457
01/12/10 01:02 PM
01/12/10 01:02 PM
Minn
SportF Offline
SportF  Offline
Minn
Would you rather have 500 HP and 600 pounds of torque, or 550 HP and 600 pounds of torque? I think you'd want the revs that make that 550. If you do have a combo of 500 HP and 600 pounds of torque there is probably something wrong with the combo and not as effiecent as it should be. I guess I agree its torque at the rear that moves the car, but that torque has to come at RPM's, which is power...which accelerate the car, eh?
Re: torque per cube? [Re: SportF] #578458
01/12/10 01:31 PM
01/12/10 01:31 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I think dollars have to be in this equation, Big HP takes more RPM and more money, Unless you have unlimited funds, Engines should be looked @ as a trade between power and dollars, I am a small block guy so I look more @ dyno sheets from builders Like RJ & Brian , Brett and a few others, Some of the art of engine building is to provide good power bands with torque and HP with in the dollars allowed,That being said I wish I had a lot more disposable income
Re: torque per cube? [Re: emarine01] #578459
01/12/10 02:36 PM
01/12/10 02:36 PM
"That being said I wish I had a lot more disposable income"
Ain't that the truth!
Chasing power and et is darned expensive after you get up there a ways!
Re: torque per cube? [Re: gregsdart] #578460
01/12/10 02:37 PM
01/12/10 02:37 PM
Hemifred, what are the specs on that 655 hemi? head type? new 99 or second gen?
Re: torque per cube? [Re: emarine01] #578461
01/12/10 02:40 PM
01/12/10 02:40 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Here is two of our dyno sheets. 451 with pocket ported SR Heads and a m1 intake.
278 @ .050 with .660 lift roller.
500 ci B1 fully ported.
Re: torque per cube? [Re: gregsdart] #578462
01/12/10 04:10 PM
01/12/10 04:10 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Greg, thats a millinium headed motor. We've discussed DTs hemi on other threads, thats the one Fred now owns, iirc.
My 540 with unported Originals has 743 lbs at 4500rpm. Cam is a 280 at .05 endurance roller and CR is 12.5. HP was right at 800/6500rpm.
Post deleted by Defbob [Re: B1Fish540] #578463
01/12/10 04:33 PM
01/12/10 04:33 PM
Re: torque per cube? #578464
01/12/10 05:03 PM
01/12/10 05:03 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
The current crop of Comp Eliminater and Pro Stock engines have reached a development point that 1.6 Ft Lbs of Torque per Cube and slightly over 2.6 HP per Cube are realistic goals. Building for Torque vs Horsepower is something of a misnomer, since a big HP number is really just a conversion of a big Torque number at a higher RPM. A rising or dead flat torque curve is the fastest way to increase HP, since the same or higher TQ number at a higher RPM increses the HP equation the quickest.
TQ x RPM/5250=HP
In order to move the location of the TQ peak and/or increase the TQ output, generally the MCSA will need to increase, it seems to be a defined TQ predicter for a well developed engine.
Be a Rebel- Break the Laws of Physics!
Re: torque per cube? [Re: mbogina] #578465
01/12/10 05:55 PM
01/12/10 05:55 PM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
HP DOES NOT EXIST per sa.
Torque is the only measure of rotational energy PERIOD!
HP is torque x RPM/5252.
Cam profile, head flow, CSA and engine volume (CID) can drastically effect where and when you make torque.
HP is only the ability to make torque a RPM.
A big head on a small engine will make lousy low speed torque but it will be able to support RPM so it makes HP at a higher RPM. The converse is true if you have a small head on a big engine, it will make gobbs of torque but the small head will not allow the engine to breath at higher RPM to make more HP.
Thats why 440's were always perceived as torquey engines. A good amount of cubic inches with a head better suited for 350-370" engine.
Class over
Mike @MM
Re: torque per cube? [Re: MuscleMike] #578466
01/12/10 06:46 PM
01/12/10 06:46 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
now can you take the info from the equation and find the CSA or head flow or VE of the enging?
Page 2 of 3 1 2 3
