Re: Generator Help ?
[Re: 68roadrunner]
#578303
01/14/10 08:13 PM
01/14/10 08:13 PM
Challenger 1
Cincinnati, Ohio
to get the slides i went to Moore Industrial Hardware in cinncinati oh. they have a website
i got some pretty heavy # slides that lock in or out, so it can't slide on its own. i think they was about $100 or so for the pair,dont quote me on that.
then i made a metal tray and riveted it to the slides.welded some angle on the outside to anchore it to the trailer.
![](/ubbthreads/images/graemlins/iagree.gif)
This is where to get the slides, because they are heavy duty and will have a better chance of standing up to the vibration of the road and while the genset is running.
I don't think you will find any slides at Home depot like these. My ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: chryco]
#578305
01/16/10 04:52 AM
01/16/10 04:52 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
Did you fab the door as well . My Haulmark doesn`t have one . Was wondering who you got the hardware from ? Chryco
I found my generator door on ebay. It was less than a hundred bucks shipped with a buy it now price. Nice aluminum frame and fiberglass panel with a slide door/vent built right in. I can/t remember the nmae on it as it is out in the shop, but I can get the info tomorrow. Only thing it needs is the panel painted to match your trailer as they come in white. It is identical to the generator door on my brothers 2007 vintage trailer. Hope this helps, Beep
Did a little searching and found the info in my ebay account. The seller has an ebay store called Centralia Machine and the seller was 4ccenet. The listing was "24 x 36 polar white ventilated generator door with frame". In October they had 3 available. If you still need the manufacturer's name on the door, pm me and I'll get it for you. Beep
[Re: Bigbeep]
#578306
01/16/10 10:10 AM
01/16/10 10:10 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Thanks !
here it is .........
http://fiberoptictrailers.com/CM&FParts&AccessPage.htm
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: Sub95]
#578307
01/16/10 10:27 AM
01/16/10 10:27 AM
Challenger 1
Cincinnati, Ohio
the ones home depot sell are ball bearing slides and i have not had one issue with them, even being sand blasted for the last 8 years at the beach.
![](/ubbthreads/images/graemlins/thumbs.gif)
