Re: Generator Help ? [Re: MegaDart] #578302
01/14/10 06:59 PM
01/14/10 06:59 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I made mine also using #200 drawer slides. The first time I built it about 5 years ago I used 1x4 pt that I had laying around and a piece of old countertop from a remodel job. That lasted about 4 years then fell apart. I took the whole thing down to the weld shop and they fabbed a heavy duty metal pan and bolted it to the slides. Then they bolted some 3" aluminum angle to it and I screwed that to the floor. Works fantastic.
here is the new one
Did you fab the door as well . My Haulmark doesn`t have one . Was wondering who you got the hardware from ?
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Generator Help ? [Re: 68roadrunner] #578303
01/14/10 08:13 PM
01/14/10 08:13 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
to get the slides i went to Moore Industrial Hardware in cinncinati oh. they have a website
i got some pretty heavy # slides that lock in or out, so it can't slide on its own. i think they was about $100 or so for the pair,dont quote me on that.
then i made a metal tray and riveted it to the slides.welded some angle on the outside to anchore it to the trailer.
This is where to get the slides, because they are heavy duty and will have a better chance of standing up to the vibration of the road and while the genset is running.
I don't think you will find any slides at Home depot like these. My
Re: Generator Help ? [Re: Challenger 1] #578304
01/16/10 04:13 AM
01/16/10 04:13 AM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
the ones home depot sell are ball bearing slides and i have not had one issue with them, even being sand blasted for the last 8 years at the beach.
Re: Generator Help ? [Re: chryco] #578305
01/16/10 04:52 AM
01/16/10 04:52 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Chryco
I found my generator door on ebay. It was less than a hundred bucks shipped with a buy it now price. Nice aluminum frame and fiberglass panel with a slide door/vent built right in. I can/t remember the nmae on it as it is out in the shop, but I can get the info tomorrow. Only thing it needs is the panel painted to match your trailer as they come in white. It is identical to the generator door on my brothers 2007 vintage trailer. Hope this helps, Beep
Did a little searching and found the info in my ebay account. The seller has an ebay store called Centralia Machine and the seller was 4ccenet. The listing was "24 x 36 polar white ventilated generator door with frame". In October they had 3 available. If you still need the manufacturer's name on the door, pm me and I'll get it for you. Beep
Re: Generator Help ? [Re: Bigbeep] #578306
01/16/10 10:10 AM
01/16/10 10:10 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Chryco
Thanks !
here it is .........
http://fiberoptictrailers.com/CM&FParts&AccessPage.htm
Re: Generator Help ? [Re: Sub95] #578307
01/16/10 10:27 AM
01/16/10 10:27 AM
Cincinnati, Ohio
Cincinnati, Ohio
