Edelbrock fitting adapter inverted flair part# 8090 from Summit, Jeggs or anyone that sells Edelbrock parts.
It is not identical but it fits & should do the trick, like the Carter fitting the Edelbrock one has a 3/4" hex although it is a bit (.177") longer, brass rather than steel (different colour) & is not counter bored for the factory style mesh filter although this could be easily done with a standard drill in a lathe or drillpress if required.
At least it would get you going until you found an original one.
