Hydraulic roller cam with solid roller lifters? #577954
01/09/10 08:55 PM
01/09/10 08:55 PM
Australia
gg408 Offline OP
gg408  Offline OP
Australia
Does it work and is it worth the effort.
Reason I ask is that I don't want to run real high spring preasures as the car will be used on the street a bit.
Have heard some bad things.
Cheers
GG408
Re: Hydraulic roller cam with solid roller lifters? [Re: gg408] #577955
01/09/10 10:07 PM
01/09/10 10:07 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I believe Ryan is running that set up in his motor.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
