67 coronet axle spec #577692
01/09/10 06:12 PM
01/09/10 06:12 PM
Lost highway hotel.
Dart_Girl Offline OP
Eve Of Destruction
Eve Of Destruction
Lost highway hotel.
Does anyone know the standard axle used on the 67 Coronet wagons with a 318/auto trans?
Re: 67 coronet axle spec [Re: Dart_Girl] #577693
01/09/10 07:45 PM
01/09/10 07:45 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
As far as I know 8,3/4's were used in all 67 B bodies. The only other option was the Dana 60 in the 440 and Hemi engined automatic cars. Dana 60 was standard on 440 and Hemi engined 4speed cars.
Re: 67 coronet axle spec [Re: rapom] #577694
01/10/10 04:55 PM
01/10/10 04:55 PM
Lost highway hotel.
Eve Of Destruction
Eve Of Destruction
Lost highway hotel.
Hey thanks! I appreciate your response.
I tore it apart last night and yes, to My surprise (I didn't know this) it was an 8 and 3/4 rear. The neat thing is that all the parts were numbered which will make it easier for Me to replace them.
The bearings that is were numbered. Good thing that this thing broke down before it killed Us. I read stories here on Moparts about the whole axle coming off the housing while it was rolling! Good thing that didn't happen here.
Thanks again!
DG
Re: 67 coronet axle spec [Re: Dart_Girl] #577695
01/10/10 08:40 PM
01/10/10 08:40 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
No problem, if you are going to use the stock type bearings, make sure you pack them well with a good bearing grease. (As they are not lubed by the axle gear oil) There are seals in the axle tubes just inside where the axle bearings seat that prevent the gear oil from getting to the bearings. If the seals are bad you will end up with gear oil in your brake drums.
Re: 67 coronet axle spec [Re: rapom] #577696
01/11/10 11:30 AM
01/11/10 11:30 AM
Lost highway hotel.
Eve Of Destruction
Eve Of Destruction
Lost highway hotel.
Geeze thanks for the heads up as that is the last thing I need at this point.
This car is killing Me!
Re: 67 coronet axle spec [Re: rapom] #577697
01/11/10 12:30 PM
01/11/10 12:30 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Slant motored B-body cars had 7 1/4 inch rears
