THere's at least a half dozen F.A,S,T, racers here on Moparts.
Me, Dave Dudek, Tom Cannon, Ed Cook, Tom Cannon, Gene Wisley, and more.
All the details of F.A.S.T. racing, including rules, race format, and history, can be found at
www.fastraces.org.Engine rule:
2.00 ENGINE
2.01 Engine block must appear to be a correct* original block and it must be an original vintage OEM or vintage OEM replacement of the same engine family and exterior size and must be made from the same material as the correct* original block. Also, a new OEM replacement block is allowed only if it duplicates a legal vintage block in design, material, appearance, bore size and performance. No aftermarket blocks are allowed. Replacement OEM blocks that have raised decks, raised cam or bigger bores are not allowed. Block casting number does not have to be correct*. No aftermarket blocks allowed.
For example:
a. A correct* 400 cid block could be replaced with a vintage, OEM 455 block, if it appears externally correct*, and is made from the correct* material.
b. A correct* Mopar 340 could use a 318, 340 or a 360 block, if it appears externally correct*, and is made from the correct* material.
c. A correct* 327 Chevy can use a 350 or 400 block, if it appears externally correct*, and is made from the correct* material.
d. A new Mopar Hemi standard replacement block is allowed, but a Siamese bore Mega block is not.
2.02 Dealer installed engines and dealer performed modifications are not allowed.
2.03 Cylinder Heads and Intake Manifold MUST be correct* OEM casting, have correct* original casting numbers and be of correct* original material.
This may very well be the most important and teched F.A.S.T. rule.
Note: Any cylinder head or intake manifold that is not the correct* casting number, must be approved and published on the F.A.S.T. website.
Casting date codes are not looked at and are not part of the tech process.
2.04 Internal engine modifications OK.
2.05 The entire engine compartment and engine assembly, including accessories, must appear correct, except for items specifically defined otherwise in these rules. Appearance of the engine will be inspected with the air filter housing off and on. Removal of pollution control air pump is allowed. Engine torque strap OK.
Engine color should appear stock.
2.06 No Nitrous Oxide allowed.
2.07 Lightweight mini starters OK. If painted to appear as stock as possible.
2.08 Aftermarket harmonic balancers are OK, if painted to appear as stock as possible.
![](/ubbthreads/images/graemlins/thumbs.gif)
