Re: Block Rust.... [Re: 9secondsatellite] #573638
01/05/10 05:47 PM
01/05/10 05:47 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
pancakes?
Re: Block Rust.... [Re: 9secondsatellite] #573639
01/05/10 05:48 PM
01/05/10 05:48 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Molasses.
Molasses ???
Yeah! It really works!
Thatīs chemistry!
i like the molasses idea but what do you do with the stuff when you're done? how do you get rid of it?
I have a hand dug storm drain in my backyard , done by a previous owner , I just dumped it in there , the flies loved it ...
I did this as a test to a set of valvecovers , didn't do it in the order that scott stated , but I'll try it like that and see how it works out that way , the covers need more work and I have a couple blocks to do .
I'll say this , the stuff stinks after a while , I think Tadjou ... RIP ... knew what he was doing when he did it in the colder months and just heated it up , I'm thinking it stunk less ???
Re: Block Rust.... #573640
01/05/10 05:50 PM
01/05/10 05:50 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Just dump it on the ground, it's organic and completely safe.
Re: Block Rust.... [Re: ScottSmith_Harms] #573641
01/05/10 06:17 PM
01/05/10 06:17 PM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Re: Block Rust.... [Re: dart_73_br] #573642
01/05/10 10:07 PM
01/05/10 10:07 PM
Dyno1 Offline
Dyno1  Offline
My engine shop has had many blocks like that. Hot tank 1st, then into the bead blaster, looks like new when finished.
