Re: Felpro head gasket water ways.
[Re: rebel]
#572969
01/11/10 06:54 PM
01/11/10 06:54 PM
Posts: 1,200 UK
602heavy
UK
i run the reverse flow pump & found if i drilled a hole in the gasket by where the 2 exhausts are together that improved cooling tremendously. the holes up by the lifter valley were just to help clear the air bubbles.
Thanks Rebel , the only water ways between the centre ex valves are on the valley side , did you open these up? , the holes on the header side are between the intake valves , this is a siameese block so cooling will always be a problem to some extent , as Rebel says , opening up the centre waterway on valley side has got to show some inprovement? , maybe these gaskets are fine on a standard block , i'm just thinkin out the box regards the siamese blocks , reverse cooling is'nt an option.
Thanks.
