In my earlier post I said I was NOT having any cooling issues once the fan shroud was put on...
I recently put A/C in the car, now it get's hot (190-210).
I have a after market 26" 2 row (brass/copper) radiator w/shroud and driving it around town, not stopping, it gets HOT!
So I ran across a site that has the same exact radiator (dimension wise) in "aluminum, all aluminum. I plan on buying the direct fit all aluminum radiator and replacing the water pump.
My question is, does anyone know if it will help to replace those items?
The engine is a 360 mildly built (350+ ponies) .030 over. I've tried re-timing several times, adjusting the air/fuel mixture on the carb and not running the a/c at all...
I'm up for any suggestions!! Help!!
