1968 Road Runner post door GLASS, what interchanges ??? #572785
01/04/10 08:38 PM
01/04/10 08:38 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I have a 1968 Road Runner Post car and need tinted drivers door glass. I have the clear glass. What other cars have the same glass?
The attached picture... the top glass is the tinted post
car glass (This is the passenger side)
Re: 1968 Road Runner post door GLASS, what interchanges ??? [Re: Kam*Kuda] #572786
01/04/10 11:34 PM
01/04/10 11:34 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
For post glass you are limited to the Plymouth Satellite, Belvidere, and the Dodge Coronet Models, Post glass is the same..
I believe new tinted glass is available on Epay...
Otherwise it was only used on Air cond cars or as an extra cost option...
Re: 1968 Road Runner post door GLASS, what interchanges ??? [Re: sthemi] #572787
01/04/10 11:54 PM
01/04/10 11:54 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
No '68-'70 Satellite 2-door coupes; Belvie, RR, Coronet coupe door glass interchanges. Hardtops use a chrome molding & seal and a squared upper rear corner.
Re: 1968 Road Runner post door GLASS, what interchanges ??? [Re: Kam*Kuda] #572788
01/05/10 08:20 AM
01/05/10 08:20 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Rob,
I'll have that number for you tonite.
Re: 1968 Road Runner post door GLASS, what interchanges ??? [Re: Kam*Kuda] #572789
01/05/10 09:45 AM
01/05/10 09:45 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
as you can see by your picture 68 is a one year only glass , it's different at the bottom , you are limited to 68 only B body coupes , good luck if you can't find a new one .
I'm not sure but you MIGHT be able to change the window regulator to a 69/70 part and that will increase your chances of finding a replacement ?
Re: 1968 Road Runner post door GLASS, what interchanges ??? [Re: JohnRR] #572790
01/11/10 08:25 AM
01/11/10 08:25 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
A firend has a 69 door. The glass looks identical yet there is one extra hole. DOes that seem right?
Unfortunately it is not tinted. but it could add an option for more available options
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
