Re: 470 lowdeck stroker/ anyone try it?
[Re: CDoering]
#572076
01/04/10 08:52 PM
01/04/10 08:52 PM
Posts: 3,547 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I am not sure if Indy stocks that number. They have some proprietary Wiseco stuff I believe.
KB makes a forged piston that is within .015 of the compression height you would need. I am quite certain you could face mill .015 off the top of those pistons.
Diamond will make 2 changes to a shelf stock piston for a minimal charge. ( semi-custom/stock). If you have some nice Crower rods, then your should put a good piston in it and get EXACTLY what you need with the Diamonds, unless the Indy deal works out.
RIP Monte Smith
[Re: Streetwize]
#572077
01/04/10 08:59 PM
01/04/10 08:59 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I prefer a 470 Low deck to a 493RB for the same money. The 470 is a great bucks down combination in both blocks that's real easy on parts and runs forever when carefully assembled...3.90 stroke is the same as a 455 Buick BTW
great engine mike
[Re: CDoering]
#572083
01/05/10 01:21 AM
01/05/10 01:21 AM
Posts: 819 Eastern WA
ProStock1320
Eastern WA
...using 6.385 rods...
What about all the hullabaloo of rod to stroke ratio? While there are clearly 470s using the 6.385 rods, the shift appears to be toward the longer rod and shorter piston. Any reason for this? Not looking to hijack, just want to hear thoughts since we're discussing the 470s. Thanks.
[Re: CDoering]
#572085
01/05/10 01:38 AM
01/05/10 01:38 AM
Posts: 793 Utah
topbrent
Utah
[Re: 10secGTX]
#572087
01/05/10 10:22 AM
01/05/10 10:22 AM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
I have a question...headers if I went from a RB w/ eddys to a BB stroker w/eddys just plain old RPM'S how much will it change the location of the headers in 67 B body ? will I need BB specific...sorry for the Hi jack
BB ? Do you mean B vs an RB ? What headers do you presently have ? Most headers are a compromise so they will fit many chassis and both deck heights , some work better with one combo vs the other . the only company I know of that makes a deck height specific header is TTi , so if you don't have TTi's you should be all set.
If you have an exhaust system on the car with a crossover pipe you will have to modify the headpipes as the headers will be closer together once installed .
#572088
01/05/10 10:23 AM
01/05/10 10:23 AM
JohnRR
A gulag near you.
A Muscle Motors Stroker kit is the same as a 440 Source kit. If you call Muscle Motors try to talk to Mike NOT Eric his secretary
Interesting , joined yesterday and only 2 posts , both bashing a board sponser ... Muscle Motors ????
Post deleted by moparts
[Re: JohnRR]
#572089
01/05/10 10:44 AM
01/05/10 10:44 AM
#572090
01/05/10 10:46 AM
01/05/10 10:46 AM
JohnRR
A gulag near you.
Definately not bashing....just speaking from experience
Did the crank say [Edited by Moparts - Family Friendly Site - Keep it clean] on it like the one BG posted in the other thread ?
