Re: 470 lowdeck stroker/ anyone try it? [Re: CDoering] #572076
01/04/10 07:52 PM
01/04/10 07:52 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I am not sure if Indy stocks that number. They have some proprietary Wiseco stuff I believe.
KB makes a forged piston that is within .015 of the compression height you would need. I am quite certain you could face mill .015 off the top of those pistons.
Diamond will make 2 changes to a shelf stock piston for a minimal charge. ( semi-custom/stock). If you have some nice Crower rods, then your should put a good piston in it and get EXACTLY what you need with the Diamonds, unless the Indy deal works out.
RIP Monte Smith
Re: 470 lowdeck stroker/ anyone try it? [Re: Streetwize] #572077
01/04/10 07:59 PM
01/04/10 07:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I prefer a 470 Low deck to a 493RB for the same money. The 470 is a great bucks down combination in both blocks that's real easy on parts and runs forever when carefully assembled...3.90 stroke is the same as a 455 Buick BTW
great engine mike
Re: 470 lowdeck stroker/ anyone try it? [Re: Sport440] #572078
01/04/10 08:12 PM
01/04/10 08:12 PM
buffalo,new york
W
WhiteB1Duster Offline
W
buffalo,new york
i love mine .koffels built 470 b1-bs headed 73 duster 2970lbs goes 9.60s .very low mantnance.
Re: 470 lowdeck stroker/ anyone try it? [Re: 1swingin] #572079
01/04/10 10:11 PM
01/04/10 10:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve got the "old school" kit. Stock off set ground(3.900 stroke)413 steel crank, Eagle 6.385 rods,je 12.11 comp pistons and w/rpm heads it runs pretty good and have almost 9 years in the same 400 block w/same rods and crank. Bulet proof street/strip combo that keeps on ticking.
Re: 470 lowdeck stroker/ anyone try it? [Re: Thumperdart] #572080
01/04/10 10:54 PM
01/04/10 10:54 PM
Ohio
jdfpam Offline
jdfpam  Offline
Ohio
I agree with Muscle Mike and Todd. Great combination. We have done the machine work on dozens of them over the years with very good results. Good choice.
Jeff Day
Precision Automotive Machine
Canton, Ohio
Re: 470 lowdeck stroker/ anyone try it? #572081
01/04/10 11:42 PM
01/04/10 11:42 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
Before all the new aftermarket parts the 452/470 low deck combination was unbeatable for durability and consistency.
Re: 470 lowdeck stroker/ anyone try it? [Re: jdfpam] #572082
01/04/10 11:44 PM
01/04/10 11:44 PM
CDoering Offline
CDoering  Offline
Competition Wedge,
I realize that custom pistons are the way to go. I am going to be using some custom Diamonds in a 499 build I have also. I was looking at all these parts I have and the only thing holding me from building a 470 is pistons. I have everything to build a mild 470 utilizing ported Stage V heads and a RPM intake. I just don’t want to spend a lot. I would rather save the coin and use it towards the bigger motor.
Re: 470 lowdeck stroker/ anyone try it? [Re: CDoering] #572083
01/05/10 12:21 AM
01/05/10 12:21 AM
Eastern WA
P
ProStock1320 Online content
ProStock1320  Online Content
P
Eastern WA
...using 6.385 rods...
What about all the hullabaloo of rod to stroke ratio? While there are clearly 470s using the 6.385 rods, the shift appears to be toward the longer rod and shorter piston. Any reason for this? Not looking to hijack, just want to hear thoughts since we're discussing the 470s. Thanks.
Re: 470 lowdeck stroker/ anyone try it? [Re: ProStock1320] #572084
01/05/10 12:26 AM
01/05/10 12:26 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
I have a question...headers if I went from a RB w/ eddys to a BB stroker w/eddys just plain old RPM'S how much will it change the location of the headers in 67 B body ? will I need BB specific...sorry for the Hi jack
Re: 470 lowdeck stroker/ anyone try it? [Re: CDoering] #572085
01/05/10 12:38 AM
01/05/10 12:38 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Looks like KB forged pistons are now called ICON.
6.535 rod, 9.98 B deck, 1.48 comp ht:
http://www.kb-silvolite.com/test/icon/ic...mp;RodLen=6.535
7.1 rod, 10.725 RB deck, 1.66 comp ht:
http://www.kb-silvolite.com/test/icon/ic...&RodLen=7.1
Ross Piston chrysler application chart:
http://www.rosspistons.com/products/index.php#cid=7&acc_id=0&type_id=2&vehicle_id=42
Re: 470 lowdeck stroker/ anyone try it?(Iam sold on it! [Re: topbrent] #572086
01/05/10 01:43 AM
01/05/10 01:43 AM
somewhereintheswampsofjersey
1swingin Offline OP
1swingin  Offline OP
Well,ive done the research,got great input from you guys,spoke with mike from muscle motorss and sam from indy. Iam ordering the kit tomorow. The indy kit is on sale and pound for pound mike said is the best kit for stock style heads and he told me its just a great,reliable combo that makes great power and torque. He told to have the crank shotpeened and watch the taper on the jornals but minimal block cearance and it just works great! Thank you all for your help. This is gonna be fun! Anyone got a used rotating assembly for sale?!!! hey,iam cheep! I had to try! Thanksagain! I will keep you all posted. Its a 383,I swear!!!!
"I aint here on buisness baby,Iam only here for fun"
Re: 470 lowdeck stroker/ anyone try it? [Re: 10secGTX] #572087
01/05/10 09:22 AM
01/05/10 09:22 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
BB ? Do you mean B vs an RB ? What headers do you presently have ? Most headers are a compromise so they will fit many chassis and both deck heights , some work better with one combo vs the other . the only company I know of that makes a deck height specific header is TTi , so if you don't have TTi's you should be all set.
If you have an exhaust system on the car with a crossover pipe you will have to modify the headpipes as the headers will be closer together once installed .
Re: 470 lowdeck stroker/ anyone try it? #572088
01/05/10 09:23 AM
01/05/10 09:23 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
A Muscle Motors Stroker kit is the same as a 440 Source kit. If you call Muscle Motors try to talk to Mike NOT Eric his secretary
Interesting , joined yesterday and only 2 posts , both bashing a board sponser ... Muscle Motors ????
Post deleted by moparts [Re: JohnRR] #572089
01/05/10 09:44 AM
01/05/10 09:44 AM
Re: 470 lowdeck stroker/ anyone try it? #572090
01/05/10 09:46 AM
01/05/10 09:46 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Definately not bashing....just speaking from experience
Did the crank say [Edited by Moparts - Family Friendly Site - Keep it clean] on it like the one BG posted in the other thread ?
