KB spiral pin locks - best way to install??
#570422
01/02/10 10:26 PM
01/02/10 10:26 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
okay, I'm installing my rods (scat H-beam) onto my pistons (KB forged). They are floating pins with spiral locks at each end. Whats the best way to install these spiral locks?
Re: KB spiral pin locks - best way to install??
[Re: StealthWedge67]
#570425
01/02/10 10:32 PM
01/02/10 10:32 PM
beedees
#570429
01/03/10 01:04 AM
01/03/10 01:04 AM
RapidRobert
If you put the eyebrows to the outside you're gonna be a bit upset w yourself. If no valve reliefs reversing the pin offset (if your pistons have an offset pin) you can live w that & may prefer it.
[Re: RapidRobert]
#570431
01/03/10 02:11 AM
01/03/10 02:11 AM
StealthWedge67
Puyallup, WA
Those both deal with how the piston & rod are situated in the motor, & I'm aware of that. I thought he meant there was something that could be wrong with how the piston is mounted on the rod. I think we're good.
Thanks again, guys!
